How Close Must a Charged Pen Be to Pick Up Aluminium Foil?
  • Thread starter Thread starter luckyducky
    Aluminium Charged
luckyducky
A clear plastic pen of length 14.5 cm is rubbed with wool. The charged plastic pen is held over a small uncharged disk shaped piece of aluminium foil of diameter 0.5cm. How close you must move the pen to the foil in order to pick up the foil?
Ok I thought I would let the disk be a diople and let the pen be a point charge but nothing worked. Please explain to me how I should do this question.
Thank you very much
You migth want to study the forum rules. You MUST attempt the problem, and tells us what relations and formulas you know.
This is what I did?
Ok this is what I did but don't know whether it is right or not:
E = 1/(4 pi epslon) * Q/d^2 is the electric field of the pen
I said that the aluminium foil works like a capacitor therefore:
(qA)/epsilon - 1/(4 pi epslon) * Q/d^2 = 0 also Q=10 nanoC the charge of the pen
then I can figure out the charge of the foil on one side I think(I hope this is right)
Electricfield of disk = ((Q/A)*(s/R))/2epsilon where s=thickness of the disk
also m=dV is the formula for density, but is V= pi r^2 s
then if the above is right we know F = mg
F = ((Q/A)*(s/R))/2epsilon m = D pi r^2 s
therefore:
((Q/A)*(s/R))/2epsilon = D pi r^2 s g
But is this even right, I really need you guys to help me please HELP me !
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
