Charging a system of metal rods
The discussion focuses on calculating the maximum charge that can accumulate on two metal rods of definite length without causing electrical discharge. The electric field of a charged rod is approximated using the formula for an infinite rod, but concerns arise regarding its applicability to finite rods, as the field strength varies across the surface. The charge distribution on conducting rods is not uniform, with higher densities near the ends, complicating the calculations. A suggestion is made to solve Laplace's equation numerically to determine the electric potential and subsequently the electric field. The user seeks a rough estimate for maximum charge to proceed with their model, questioning the validity of using infinite rod assumptions.
rijulg
I am trying to charge a system of two metal rods, of definite length, placed a certain distance apart. But before setting up the rods and hooking them to any battery, i wish to know the magnitude of charge that will be accumulated on the rods and what is the maximum possible charge on the rods, so as to just prevent electrical discharge
we know that field of a charged rod (infinite, or finite near center) is ~ E= λ/(2πϵr), and maximum possible electric field is 3 x 10^6 N/C, so putting the values we get relation between λ and r, knowing length of rod, we can calculate maximum charge on one rod with respect to radius of cross section of rod. But i doubt the applicability and validity of this method
Why?
jtbell said:
Why?
because this approximation is for infinite charge rod, and for a finite charge rod, the field might be more on the axis, so when i will charge my rod according to calculations of infinite rod, it may discharge from the axis
Ah, I overlooked the "definite length" in your first post. It seems you want the electric field at all points near a cylinder with given length. This is not a simple problem, even if the cylinder has a circular cross-section (the most symmetric situation) and the charge is uniform. The field does not have the same strength or direction everywhere on the surface. It's not like an infinite circular cylinder where you can assume the field is perpendicular to the surface of the cylinder.
Also, you're using conducting (metal) rods, which means the charge is not uniformly distributed. It's all at the surface of the rods, and with probably a higher (surface) charge density near the ends of the rod.
I think you have to solve Laplace's equation numerically for the electric potential, with the condition that the surfaces of the rods are equipotentials, then find the electric field by taking the gradient of the potential. Maybe someone else has a better idea.
Actually i need very less out of the problem, i just need to find out the maximum amount of charge possible on the rod, even a rough estimate and then i will charge it with somewhat lesser charge than the acquired answer, but to find out that rough estimate i am not sure if infinite rod estimation will be of any actual use, if someone can even just give a way to find out an assuring approximation of max. charge so that i can start building a model, it would be great
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
