What is the charging current for a 120 ampere-hour storage battery?
  • Thread starter Thread starter da-outcast
    Current
To charge a 120 ampere-hour storage battery in 8 hours, the charging current can be calculated by dividing the ampere-hours by the charging time, resulting in a current of 15 amperes. For a lead-acid battery designed for a continuous discharge of 180 amperes over 5 hours, the time to discharge at a steady current of 220 amperes can be determined using a proportion, yielding approximately 4.5 hours. The discussion emphasizes the simplicity of these calculations, suggesting that they do not require complex RC equations. Participants also engage in light-hearted banter about the problem's complexity. Overall, the conversation highlights basic principles of battery charging and discharging calculations.
da-outcast
Charging current
I am total stumped on the following to questions so if someone could show me how to get started that would be good thanks.
1) A storage battery rated at 120 ampere-hours is to be fully charged at constant current in 8 hours. Calculate the charging current.
2) A lead-acid battery is designed to give continuous discharge of 180 amperes for 5 hours. Calculate the time it will be discharged by a steady current of 220 amperes.
Why don't you use the RC equations for charging and discharging? I would assume you can treat a rechargable battery like a capacity in series with a resistor.
Hint: ampere-hours is a product.
DDuardo, were you teasing?
A current is measured in amperes. To go from ampere-hours to amperes, you divide by hours! Think about it.
This is really a "proportion" problem. Let t be the time required by the 220 ampere current. Then x is to 220 as 5 is to 180.
Or, in more modern terms, x/220= 5/180.
Thank you, HallsofIvy. Yes, it was a joke. I was trying to make the poor guy complicate the problem even further seeing how you just have to multiple a couple of numbers to get the solution. :smile:
Gosh, you're evil!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
