Check if the statement is true (algebraic)
  • Thread starter Thread starter Zems
The discussion revolves around a potential error in a textbook problem involving the equation x + y + √(x - y) = 2 + √6. The user believes the textbook's solution of x = 2 and y = -2 is incorrect, as substituting these values does not satisfy the equation. Instead, they found alternative values using Wolfram Alpha, yielding x ≈ 2.09974 and y ≈ 1.84974. Additionally, they propose solving the system of equations x + y = 2 and x - y = 6, which leads to different values of x and y. The user plans to address this discrepancy with their lecturer.
Zems
I came across this problem in my textbook, i think the answer is wrong. I checked on wolfram alpha and got different results.
x+y+√(x-y)=2+√6
The solutions in the book are x=2 y=-2, however when I substituted it into the equation i get 2=2+√6
The answer i got on wolfram alpha is x=2.09974 and y=1.84974, can anyone help confirm that the solution is wrong?
So you could solve it by writing two equations in x and y:
x + y = 2
And
x - y = 6
What do you get?
y=-2 and x=4, so the answer in the book is wrong. Thanks, ill have to sort this out with my lecturer.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
