Checking a relation in S and acceleration
The discussion revolves around determining the relationship between displacement (S) and acceleration (A) given the equation S² = at² + 2bt + c. Through differentiation, participants analyze the equations derived from velocity and acceleration, ultimately concluding that acceleration is inversely proportional to S³. The correct answer to the original question is option D, indicating that acceleration decreases as S³ increases. The conversation emphasizes the importance of eliminating variables and manipulating equations to arrive at the correct relationship. Overall, the final takeaway is that A ∝ 1/S³, confirming the inverse relationship.
Raghav Gupta
If S2 = at2+ 2bt+c, then the acceleration is
A) Directly proportional to S
B) Inversely proportional to S
C) Directly proportional to S2
D) inversely proportional to S3
dS/dt = v
dv/dt = A
Differentiating both sides,
2Sv = 2at + 2b
Then again differentiating,
2SA + 2v2 = 2a
So,
S = (a-v2)/A
We can say that B option is correct or not?
as there is also a velocity term which is not constant and can be written as differential of S.
As you suspect, the varying v is a problem. Your two stages of differentiation yield two equations with three variables, A, v and S. Use an equation to eliminate v.
Which equation should I use?
If I use the first equation which I have differentiated the term t will come which is also not constant.
You also have the undifferentiated initial equation.
But from it I am only getting,
## S = \sqrt{at^2+2bt+c} ##
What is the use of this?
You can use it to eliminate t, leaving an equation with only accn, S and constants. It may be messy.
But the equation is not linear in terms of t, it's quadratic, we will not get a definite value for t.
I think you'll find there's some cancellation. It works out ok, just do it.
You can choose the root which can be positive if you are worried about the two roots. And you can do the same with the other root.
So getting, $$ t = \frac{-b+ \sqrt{b^2-ac+S^2a}}{a} $$
Now what should I do?
Substituting for v will get me a t term which is not constant.
You got that v=(at+b)/S Substitute t here, to get v in terms of S.
Hmm okay, there were lot of cancellations
Finally getting
## S = \frac{ac-b^2}{A} ##
So S is inversely proportional to A, means v is constant judging from the second differential of my attempt.
Finally getting
I do not think it is correct. Check.
And remember, you need the acceleration in terms of S.
Oh yes, thanks
I did not wrote the denominator S2
So finally S3 is inversely proportional to A.
So the acceleration is inverse
Raghav Gupta said:
Oh yes, thanks
The question is A, in terms of S. Formulate your answer this way.
I know that both are same
If acceleration is inversely proportional to S3,
then S3 is also inversely proportional to acceleration.
Yes, but you should answer the question. The two sentences are not the same. And you have to choose among the given answers. Is one of them identical with "S3 is inversely proportional to A"?
Yes the 4th or D option is correct.
Are you asking to me for a formula so others learn from this thread of A in terms of S?
It would be nice :oldsmile:
So should I write also how I differentiated in my attempt.
What is product rule of differentiation, what is the meaning of differentiation,
how I got the value of t, how we find quadratic roots etc.?
In general if one wants to learn in this thread he/she should ask questions as we don't know what they are expecting.
Also identical has identical or same meaning as same
See
https://www.google.co.in/#q=identical+meaning
Would you say 3*1 is not same as 9/3 but they are identical?
No, you do not need to explain everything but you should show your solution that it can be followed.
See
Yes, I say. If your teacher asks you what is 3*1 would you answer that it is 9/3?
Why not for a joke.:approve:
Okay so ultimately the formula## A = \frac{ac- b^2}{S^3} ##
Or A ∝ 1/S3
Or A ∝ 1/S3
It is all right now.
Thanks ehild by the way. Some anger came in my post 20, which I know is not good.
You are welcome. And you could not make me angry :biggrin:
Likes Raghav Gupta
I did this without solving for explicitly solving for t.
Start with your solution in the OP.
2Sv = 2at + 2b (1)
2SA + 2v2 = 2a (2)
So,
S = (a-v2)/A (3)
Solve equation (1) for v which is dS/dt :
##\displaystyle\ v=\frac{at+b}{S}\ ##​
Rewrite equation (3), solving for acceleration. Use notation d2S/dt2 rather than A.
##\displaystyle\ \frac{d^2S}{dt^2}=\frac{a-v^2}{S}\ ##​
Now substitute the expression for v into this as well as some other manipulation..
##\displaystyle\ \frac{d^2S}{dt^2}=\frac{aS^2}{S^3}-\frac{(at+b)^2}{S^3}\ ##​
Substitute the original expression for S2 into the numerator and do some basic algebra.
##\displaystyle\ \frac{d^2S}{dt^2}=\frac{a(at^2+2bt+c)}{S^3}-\frac{a^2t^2+2abt+b^2}{S^3}\ ##​
Then there is significant cancellation. No t remains.
Likes Raghav Gupta
Very nice, Sammy!
Thanks Sammy. This was a bit fast way to solve.
