Why Are Water and Solids Excluded from Equilibrium Constant Calculations?
Water and solid substances are excluded from equilibrium constant calculations because their concentrations remain effectively constant during reactions, making their inclusion unnecessary for accurate calculations. The discussion clarifies that while the concentration of water is about 55.5 moles/liter, its slight changes during reactions are negligible for most practical purposes. The concept of activity is introduced, indicating that for gaseous reactants and products, their behavior is better described by partial pressures rather than concentrations. The relationship between the dissociation of acetic acid and its remaining concentration is explained through stoichiometry, emphasizing the importance of understanding initial and final concentrations. Overall, simplifying assumptions in equilibrium calculations help streamline the process without significantly impacting the accuracy of results.
Misr
1-The concentration of water,solid substances and precipates should not appear in the equilibrium constant equation Kc , why?I don't understand.Please don't tell me that because their concentration remains constant whatever their quantities. because I have read these words tens of times and I don't really understand them.
2-according to my textbook " if the reactants and the products are in the gasoeus state,the concentration is expressed by their partial pressure" What does this mean?
3-CH3COOH <----->CH3COO- + H3O+
let a be the no. of dissociated moles.So if we want to calculate the concentration of CH3COOH why should we say its remaining concentration=C-a,where C is the orginal concentration of CH3COOH before dissociation?.
4-H2O <---->H+ + OH-
Kc= [H+] [OH-]/[H2O]=10^-14
Kw=[H+] [OH-] = 10^-14
how could the two equations have the same value?why we are totally neglecting water?and what is the importance of calculating Kw?
I've asked a question here here but it made no sense so please don't repeat the same answer.
http://answers.yahoo.com/question/i...sH4G60Dty6IX;_ylv=3?qid=20101210130754AASJDiN
Help me please I'm very confused!
Thanks in advance.
Concentration of water is almost constant - it is about 55.5 moles/liter. Even if water reacts with some of the substances present, its concentration rarely changes by more than tenths of percent. We rarely know equilibrium constants with accuracy high enough for this change to make a difference. So in most cases we can safely assume water concentration to be constant - but it is not always true.
Solids are not dissolved, they are reacting only on the surface, it is enough that they are present to take part in the reaction. Concentration of the solid - which is separate from water - doesn't make much sense.
Not concentration, but activity, in fact each time we talk about reaction quotient we use activities, not concentrations. As a first approximation concentration and activity have the same value.
Do you know what partial pressure is?
Stoichiometry. Imagine you started with 1 mole of acetic acid and 0.1 moles dissociated - obviously 1-0.1=0.9 moles are left. Now imagine it happened in a known volume of solution - you start with C=1/V, concentration of dissociated acid is a=0.1/V, concentration of the left acid is (1-0.1)/V=C-a.
They don't have the same value. See water ion product page.
Actually this is very helpful
1-
Yes.but if what is the problem if it is constant? why don't we substitute with the concentration of water as 55.5 moles/liter ?and what is the relation between calculation of Kw and assuming water concentration constant?
2-
yes i know.Do u mean by "activity" the rate of chemical reaction ?
how?can u give me an example?
3-
got it now!
4-
as usual..a mistake in my book.
Thanks very much.
Not sure what you are asking about. We ignore water concentration to make calculations easier. It doesn't mean it is not there - just like in the case of water ion product, we move it to the equilibrium constant. This way we have one number less to worry about, it makes calculations easier.
No, rate is rate, activity is activity. For example
a_{H^+} = f_{H^+}[H^+]
activity of H+ equals its concentration times activity coefficient. For water ion product
K_w = a_{H^+}a_{OH^-}
For diluted solutions activity coefficients equal 1, for not too concentrated solutions (say below 0.1M) they are identical for ions of the same charge (so fH+=fOH-) and are less than 1. See ionic strength and activity coefficients. Please note that this is just an approximation of what is happening in reality - better one than using just concentrations, but failing in more concentrated solutions. In fact despite over 100 years of efforts we still don't have a reasonable theory allowing calculation of activities of ions in more concentrated solutions.
Misr said:
another question:
In Ostwald law, sometimes we assume (a) as no. of dissociated moles, sometimes we assume (a) as degree of dissociation which equals no. of dissociated moles/the total no. of moles of a substance before dissociation
http://www.pinkmonkey.com/studyguides/subjects/chem/chap12/c1212701.asp
so, what is (a) ?
There is some problem with formatting on the page, seems to me like whenever they use "a" they in fact mean α (degree of dissociation).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
