(Chemistry) Ka of unknown acid by titrations.
  • Thread starter Thread starter cshum00
    Acid Chemistry
To determine the Ka of an unknown weak acid, a titration with NaOH was performed, requiring 7.37mL for a complete titration, with a half-titration volume of 3.69mL. The pH of the solution was measured at 4.7, leading to the conclusion that at half-titration, pH equals pKa. Using the formula Ka = 10^-pH, the calculated value for Ka is 2.0 x 10^-5. However, there is uncertainty regarding the concentrations of the acid and its conjugate base, which complicates further calculations. The discussion highlights the need for additional information to accurately determine Ka using the concentrations of [HA] and [A-].
cshum00
Let's say that i have a unknown weak acid.
  • I prepare 10mL of the weak acid diluted in 25mL of water.
  • I titrate the solution with NaOH. 7.37mL of NaOH was needed for a full titration.
  • Therefore, half-titration of this acid was 3.69mL.
  • I measure the pH of the solution with a pH-meter and the pH was 4.7.
I want to find the Ka of the unknown acid.
Henderson-Hasselbalch pH formula for a buffer solution is:
pH = pKa + log([base] / [acid])
Since the weak acid is monoprotic, the half titration of the solution gives an equal concentration of both acid and conjugate base.
pH = pKa + log(1) = pKa
Does it mean that Ka is the concentration of [H+]?
Ka = 10^-pH = 10^-4.7 = 2.0 e-5?
Edit: Is it possible to calculate in a different way using the given data above?
Ka = [H+][A-]/[HA]
I can calculate the concentration of [H+] from the pH but i don't know the initial concentration of [HA]. And what about the concentration of [A-] ion?
Yes.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
