Circuit Problem electrical engineering
5 replies · 2K views · last reply
izelkay
Here's the question:
http://puu.sh/171ls
I have no idea where to begin. It says R(AB) = R(L) = 301 ohms. What does that mean? Does R(AB) mean the resistance from A to B? Is that the total resistance? The total resistance is equal to 301 ohms which is also equal to R(L)? I don't know. Any help would be appreciated.
http://puu.sh/171ls
Yes, RAB is the equivalent resistance of the entire network as "seen" from the terminals AB.
Ok, I think I got it. R should equal roughly 174 ohms.
Hi! Note that the circuit can be drawn as a resistance R in series with the parallel combination of: (a) a resistance of R and (b) a series combination of the resistances R and R(L).
Then, the circuit can be drawn as a resistance of R in series with the parallel combination of R and (R + R(L)).
First, determine the equivalent resistance of the parallel portion of the circuit, R and R + R(L).
[tex]\frac{1}{R(Parallel)} = \frac{1}{R + R(L)} + \frac{1}{R}[/tex]
[tex]\Rightarrow R(Parallel) = \frac{1}{\frac{1}{R + R(L)} + \frac{1}{R}}[/tex]
Multiply the numerator and denominator of the right side of the equation by [itex]\frac{R(R + R(L))}{R(R + R(L))}[/itex] to get the following:
[tex]R(Parallel) = \frac{R(R + R(L))}{R + R + R(L)} = \frac{R^2 + R(L)}{2R + R(L)}[/tex]
You are then told that R(AB) must equal R(L). This becomes the following:
[tex]R + \frac{R^2 + R(L)}{2R + R(L)} = R(L)[/tex]
Then, multiply both sides of the equation by (2R + R(L)) to get the following:
[tex]R(2R + R(L)) + R^2 + R(L) = (2R + R(L))R(L) = 2RR(L) + (R(L))^2[/tex]
[tex]\Rightarrow 2R^2 + RR(L) + R^2 + R(L) = 2RR(L) + (R(L))^2[/tex]
[tex]\Rightarrow 3R^2 - RR(L) + R(L) - (R(L))^2 = 0[/tex]
[tex]\Rightarrow 3R^2 - 301R + (301) - (301)^2 = 0[/tex]
[tex]\Rightarrow 3R^2 -301R + 301 - 90601 = 0[/tex]
[tex]\Rightarrow 3R^2 - 301R - 90300 = 0[/tex]
Applying the quadratic equation (I'll leave the details up to you) yields the following:
[tex]R = 230.7675926 ohms ≈ 231 ohms[/tex]
You will want to double check my result; but I think that I did everything okay.
^If I plug 231 in for R, Rab comes out to be about 390 ohms.
174 for R gives me 301 ohms for Rab though.
