Circuit Problem involving resistors and a switch
The circuit problem involves determining the electromotive force (emf) of a battery and its internal resistance using measurements from a voltmeter and ammeter. The emf of the battery is established as 3.68 V when the switch is open. Upon closing the switch, the voltmeter reads 3.50 V, and the ammeter indicates a current of 1.80 A. The equivalent resistance (Req) is calculated as 1.944 Ω, which is the sum of the internal resistance (r) and the circuit resistance (R).
  • Understanding of Ohm's Law (V=IR)
  • Knowledge of series resistors and equivalent resistance calculations
  • Familiarity with circuit analysis techniques
  • Basic concepts of electromotive force (emf) and internal resistance
  • Learn how to derive equations for circuits with internal resistance
  • Study the impact of internal resistance on battery performance
  • Explore advanced circuit analysis techniques using Kirchhoff's laws
  • Investigate practical applications of measuring emf and internal resistance in real-world circuits
Students studying electrical engineering, physics enthusiasts, and anyone involved in circuit analysis and battery performance evaluation.
yaro99
When switch S in the figure below is open, the voltmeter V of the battery reads 3.68 V. When the switch is closed, the voltmeter reading drops to 3.50 V, and the ammeter A reads 1.80 A. Assume that the two meters are ideal, so they don't affect the circuit.
Find the emf of the battery.
Find the internal resistance of the battery.
Find the circuit resistance R.
V=IR
Resistors in series: Req=R1+R2+R3...
I found the emf of the battery to be 3.68 V, because it is the only voltage source being read by the voltmeter when the switch is open.
I am not sure how to find the resistance.
I have come up with this:
Req = r + R
Vtotal = I*Req ==> Req = Vtotal/I = 3.5/1.8 = 1.944 Ω
1.944 = r + R
I am not sure where to go from here.
Right.
Req = r + R
1.944 = r + R
What's the voltage read by the voltmeter after the switch is closed?
rude man said:
Right.
It will be 3.5 V according to the problem, which I tried using in my calculations. I'm still confused.
OK, so how about you write an equation relating that 3.5V with the current of 1.8A, the battery voltage E and the unknown resistor r?
Then, do you have 2 equations with 2 unknowns (r and R)?
The emf of the battery is 3.68 V. If you could connect the voltmeter to the right of r it would still read that when current is flowing. But connected to the left there is a voltage drop across r. How much is it?
When you know that, since you know the current through r, you can calculate r.
You will also know the voltage drop across R, the current is the same and known so you can calculate R.
  • · Replies 17 ·
  • · Replies 62 ·
