[Circuits] Calculating the power absorbed by a resistor
8 replies · 10K views · last reply
ainster31
Circuit schematic for Fig. 3.64 with a 10 V source, a 2 A current source, a 4 A current source, and resistors labeled 6 S, 5 S and 3 S, with node current i_o marked on the left branch and the title 3.15 Apply nodal analysis to find i_o and the power dissipated in each resistor.
Attached to this post.
I have calculated the power absorbed for the 6S and 5S resistors but not the 3S resistor.
  • Handwritten circuit solution: a schematic with a 10 V source, 2 A and 4 A current sources, and 6S, 5S and 3S conductances, followed by nodal analysis at V1 giving V1 = 56/11 V and power calculations for the 6S and 5S resistors.
ainster31 said:
Circuit schematic for Fig. 3.64 with a 2 A current source, a 10 V voltage source, resistors of 3 S, 6 S and 5 S, a 4 A current source, and the current i_o labeled on the left branch.
Your values look okay for the 6S and 5S resistors. Why didn't you calculate the power absorbed by the 3S resistor?
Here is my attempt for the 3S resistor:
$$R=\frac { V }{ I } \\ \frac { 1 }{ 3 } =\frac { V }{ 6 } \\ V=2\quad V\\ \\ P=VI\\ P=2\cdot 16\\ P=32\quad W$$
Where did you get 16 A from for your P = VI calculation? You used I = 6 A in the second line.
Note that while power is indeed given by P = VI, for a resistor it's also given by V2/R and I2R, so you can avoid some steps if you already have either V or I.
Conclusion.
I used 16 A by accident. Not sure where I got the 1 from.
