Circular Motion and block track
To determine the minimum height for a block to complete a circular loop on a frictionless track, conservation of energy principles are essential. The initial energy is expressed as gravitational potential energy, while the final energy at the top of the loop includes kinetic and potential energy. A critical factor is the minimum speed required at the top of the loop to maintain contact, which is not zero. This speed can be derived using Newton's second law by analyzing the forces acting on the block. Understanding these concepts is crucial for solving the problem effectively.
interxavier
A frictionless track contains a circular section of radius R as shown. What is the minimum height at which a block must be started in order for it to go around the loop without falling off the track?
V = r*w
Fr = m*v^2/r = m*r*ω^2
I'm sorry I don't have the diagram but you can draw the equation yourselves. I'm considering using the conservation of energy in this problem, but I don't know if it's proper way.
So initially we have:
Ei = 1/2*m*v^2 + m*g*h = 0 + mgH
Ef = 1/2*m*v^2 + m*g*h = 0 + 2mgR
In particular, you know that the block falls off the track if its speed drops to zero (I'd imagine), and that the speed of the block is the same whenever it's on a given height H.
You'll need conservation of energy, but that's not all.
The key to this problem is that there is a minimum speed at the top of the track below which the block will lose contact. (That speed is not zero.) To find that speed, analyze the forces acting and apply Newton's 2nd law.
