Circular Motion - Banked Curve
To determine the banking angle for a curve with a radius of 50 m at a speed of 40 km/h without friction, the initial calculations were based on incorrect speed units. After converting the speed to 11.111 m/s, the formula tan θ = v²/(r*g) was applied correctly. This yielded a value of approximately 0.251, leading to a final angle of 14.11 degrees when using the arctangent function. The revised calculations confirm the correct approach and answer. The discussion highlights the importance of unit conversion in physics problems.
Iser
Designing an on ramp for the 401 the engineer wants cars to be able to make the turn with a radius of 50 m while traveling 40km/hr in conditions with no friction. What angle must he bank the curve at to make this possible?
FR = (m)(aR)
FR = (m)(v2)/(r)
I first started by drawing a diagram and noting the values I have for the question which are the velocity (40 km/h) and the radius (50 m). The value I we're looking for in the question is the angle the bank makes.
I first know FN(Sin θ) = (m)(v2)/R
which I can then isolate FN through which becomes
FN = (m*g)/(cos θ)Since in the actual equation has no movement in the y-axis it is:
FNsinθ = m * v2/r
Then I sub in the FN I got from the previous equation and sub it into this one getting:
(m*g/cos θ)(sin θ) = m * v2/r
which then simplifies into:
tan θ = v2/r*g
I then put in the original values I had into the equation and got 3.26 then I put 3.26 into the tan-1 thing in the calculator and got 73o degrees.
Is my answer and thought process correct?
Your thought process is perfect but your answer is not. (Convert the speed to standard units. :wink:)
Converted 40 km/h to 11.111 m/s.
Now I input the following into the formula:
tan θ = (11.1 m/s)2/(50)(9.8)
Which equals 0.2514489...
I then input that into the tan-1 function into the calculator and get:
14.11o degrees
Is this correct?
14.11o degrees
Is this correct?
Looks good!
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
