Circular Motion: Deriving r for Two Objects on a String
To derive the radius r for two objects on a string in circular motion, one must consider the forces acting on both masses m1 and m2. A free body diagram (FBD) should be drawn to identify these forces, particularly the tension in the string and gravitational force on m2. The relationship between the centripetal force needed for m1's circular motion and the weight of m2 must be established, leading to an equation that incorporates mass, radius, and the time for one revolution. It is essential to show initial attempts and calculations to facilitate guidance in solving the problem. Understanding these concepts is crucial for successfully deriving the expression for r.
makerfeldt
A small object of mass m1 moves in a circular path of radius r on a frictionless horizontal tabletop. It is attached to a string that passes through a frictionless hole in the center of the table. A second object with a mass of m2 is attached to the other end of the string. Derive an expression for r in terms of m1, m2, and the time T for one revolution. (Use any variable or symbol stated above along with the following as necessary: g.)
Not really sure of even where to start here. I drew FBD for both objects but I'm not sure where that even gets me.
Well, to begin with, what do your diagrams look like, or at least what forces have you identified as acting on each object? What coordinate system are you using?
You have to show some attempt at your own work, not just say you've done some, and you need to show exactly what it is. This is in the forum rules and it's there so that we can figure out where you are stuck.
