What is the Solution to a Confusing Circular Motion Problem?
The discussion revolves around solving a circular motion problem involving tension and acceleration. Participants emphasize the importance of drawing free-body diagrams to analyze the forces acting on each mass, specifically noting the roles of tangential and centripetal accelerations. It is clarified that only radial tensions are present, resulting in no tangential acceleration. The tension equations for each segment of the string are established, leading to a solution for the problem. Ultimately, the problem is resolved, and the participant expresses gratitude for the assistance received.
thunderhadron
The problem is as such :
Attempt to the problem:
The answer is confusing Option D
Thank you all in advance.
Tension is a force and force is related to acceleration via Newton's 2nd law. How do you determine the acceleration of a particle moving in a circle at constant angular speed ##\omega##?
Draw free-body diagrams for each mass. You need to consider the NET force acting on each particle.
But friend how could it be done without knowing the separations.
If we draw the free body diagram there would be two accelerations - tangential aT and centripetal aR
aR will be along the thread and it will equate the tension. Isn't it?
Since the only forces acting on the particles are tensions which are radial ,there will be no tangential acceleration.
The FBD in the above post#4 is incorrect.
Let the tension in the string OA be T1,AB be T2 and BC be T3.The length of each string segment be l.
Now for A, T1-T2=mv12/l
For B ,T2-T3=mv22/2l
Similarly you can write eq for C.
From this you will get the desired ratio.
Thank you very much friends. I got the answer. Problem has been cleared.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
