nathangrand
- 40
If a particle moves inside a loop then when is it's acceleration at a maximum? ie in a loop the loop
Circular motion is the movement of an object along a circular path, where the distance from the center of the circle to the object remains constant.
Circular motion is typically caused by a force acting on an object, such as the force of gravity or a centripetal force.
Circular motion involves movement along a curved path, while linear motion is movement along a straight path. Additionally, in circular motion, the object's velocity is constantly changing direction, whereas in linear motion, the velocity remains constant in both magnitude and direction.
Centripetal force is the force that keeps an object moving in a circular path. It is always directed towards the center of the circle and is perpendicular to the object's velocity.
Centripetal force is the inward force that keeps an object in circular motion, while centrifugal force is the outward force that appears to push an object away from the center of the circle. However, centrifugal force is actually a perceived force and does not actually exist. It is simply the result of an object's inertia trying to keep it moving in a straight line while it is being forced to move in a curved path.
