Circular motion vector question
A particle of mass m slides inside a vertical smooth semi-circular ring, and its motion is analyzed using conservation of energy and Newton's Second Law. The particle is released from rest at the top, and the goal is to find the reaction force at an angle of 60 degrees. Initial calculations led to an incorrect reaction force of R=1.5mg, while the expected answer is 0.5mg. The confusion arises from the direction of the radial acceleration; the correct approach involves recognizing that the radial acceleration should be negative, leading to the correct result of R=0.5mg. The discussion emphasizes the importance of accurately defining forces and directions in vector analysis.
joker_900
OK this involves vectors but I can't use the normal notation on the internet so I'm using u^ to mean the unit vector along the vector u - i hope you can help me!
A particle of mass m is constrained to slide on the inside of a vertical smooth semi-circular ring of radius r. The position of the particle is described by a polar coordinate system whose origin is at the centre of the circle with axes along the orthogonal unit vectors r^ and b^ where b is the angle between the radius vector r and the vertical line that passes through the origin.
Assuming the particla is released from rest at the top of the semi-circle, use conservation of energy and Newton's Second Law in the r^ direction to calculate the reaction force exerted by the surface at b=60 degrees.
The first part of this equation led to finding the formula for acceleration:
[/b]a[/b] = r*b''b^ - (v*v/r)r^ where b'' is the second derivative of the angle
For conservation of energy I had
2grcosb = v*v, at b=60 => gr = v*v
And for Newton in the r^ direction I had
ma = mgcosb - R , at b=60 => ma = 0.5mg - R where R is the reaction force
From the equation for acceleration in the section above, I took the acceleration in the r^ direction to be
v*v/r and I substituted this into the equation above, and then substituted the energy conservation equation to get
R=1.5mg
However the given answer is 0.5mg - where have I gone wrong?!?
R=1.5mg
The radial acceleration is toward the center of the circle so th eequation should be
ma = - mgcosb + R
ma = - mgcosb + R
I've defined r^ as going from the centre to the circumference though, so surely the mgcosb bit is positive as it acts outwards, and as R acts in the opposite direction it should be negative?
Ok, but then your acceleration will be a_r = - v^2/R !
Oh sorry (you mean v^2/r ?) I did do that but I mistyped it. I took the acceleration in the r^ direction as -v*v/r
Yes, I meant -v^2/r.
using a= +v^2/r as yopu had posted I got your final answer of 0.5 mg.
when I redid it with the correct acceleration of a=-v^2/r, I get the correct 1.5 mg.
You are saying that you got 0.5 mg using a=-v^2/r? I am confused. Please check your calculation.
