Circular Motion with time-dependent radial acceleration
A particle is moving in a circle with a radius R, experiencing time-dependent radial acceleration described by a_r=At^4. The initial position of the particle is at (R,0) when t=0. The discussion revolves around finding the distance traveled as a function of time, S(t), and converting the particle's acceleration into polar and Cartesian coordinates. It is noted that the changing radial acceleration indicates non-uniform motion, which implies the presence of tangential acceleration as well. The solution involves differentiating the velocity to find the tangential acceleration, emphasizing the complexity of the motion due to the time-dependent nature of the radial acceleration.
TwoSeventyOne
A particle is traveling on a circle with a radius R. The particle's radial acceleration is given as:
a_r=At^4
At time t=0 the particle is at (R,0).
A. Find the distance that the particle has traveled as a function of time S(t).
B. Display the particle's acceleration in polar coordinates.
C. Display the particle's acceleration in Cartesian coordinates.
##a_r=\frac {v^2} {R}##
##x=rcos\theta, y=rsin\theta##
I assumed at first that since the particle is moving in a uniform circular motion, I can use
a_r=\frac {v^2} {R}
At^4=\frac {v^2} {R}
v=\sqrt{RAt^4}
Then I treated v as \frac {ds} {dt} and got
S(t)=\sqrt{RA}*\int_0^t t'^2 \, dt' = \frac{\sqrt{RA}t^3} {3}
But then I realized that the radial acceleration changes according to time. Wouldn't that affect the solution? Also, I'm confused as to converting the acceleration from polar to Cartesian. I'm not sure if the same rules apply to acceleration and exactly what are my ##\hat r## and ##\hat \theta##.
There is nothing stating that the motion is uniform. In fact, the changing radial acceleration tells you that it is not. However, ##a = v^2/r## holds for any circular motion - otherwise the particle would not be moving in a circle.
I see. Does that mean that there is necessarily tangential acceleration as well? If so, any hint on finding it?
Yes, there must be a tangential acceleration. You have already found the velocity, so finding the acceleration is a simple matter of differentiating.
