Circulation of a flow field around circle (x-1)^2+(y-6)^2=4
MichielM
A flow field on the xy-plane has the velocity components
<br /> u=3x+y <br />
<br /> v=2x-3y<br />
Show that the circulation around the circle (x-1)^2+(y-6)^2=4 equals 4\pi
The circulation \Gamma around a closed contour is:
\Gamma=\int_C\vec{u}\cdot d\vec{s}
Because the contour of investigation is a circle, a parametrisation of the form x=1+4\cos\theta, y=6+4\sin\theta should help.
The circulation then can be calculated as:
<br /> \Gamma=\int_0^{2\pi} \vec{u} \sqrt{\left(\frac{\partial x}{\partial \theta}{\right)^2+\left(\frac{\partial y}{\partial \theta}{\right)^2} d\theta<br />
Calculating the root yields 2 so:
<br /> \Gamma=\int_0^{2\pi} 2 \vec{u} d\theta<br />
To get 4\pi out of this, \vec{u} should 1, but this is the point where I don't know how to show/calculate that. The integration of the vector is the point where I get stuck. Any help is welcome!
Careful, the radius of the circle (x-1)^2+(y-6)^2=4 is 2[, not 4.
\sqrt{\left(\frac{\partial x}{\partial \theta}\right)^2+\left(\frac{\partial y}{\partial \theta}\right)^2} d\theta only gives the magnitude of the vector d\textbf{s}.
d\textbf{s}=dx\textbf{i}+dy\textbf{j}=\left(\frac{dx}{d\theta}\right)d\theta\textbf{i}+\left(\frac{dy}{d\theta}\right)d\theta\textbf{j}
(Since x and y depend only on \theta for this curve)
Oops, little to quick in my steps. So instead of 4 i take 2 in those equations.
I think I got it now:
<br /> d\textbf{s}=dx\textbf{i}+dy\textbf{j}=\left(\frac{ dx}{d\theta}\right)d\theta\textbf{i}+\left(\frac{d y}{d\theta}\right)d\theta\textbf{j}=-2\sin \theta d\theta\textbf{i}+2\cos \theta d\theta\textbf{j}<br />
Also performing the transformation for u yields:
<br /> \vec{u}=(3x+y)\vec{i}+(2x-3y)\vec{j}=(9+6\cos\theta+2\sin\theta)\vec{i}+(-16+4\cos\theta-6\sin\theta)\vec{j}<br />
Plugging everything into the integral and taking boundaries 'full-circle' I get:
<br /> \Gamma=\int_0^{2\pi}-2\sin(\theta)(9+6\cos\theta+2\sin\theta)d\theta\vec{i}+2\cos(\theta)(-16+4\cos\theta-6\sin\theta)d\theta\vec{j}<br />
Taking the integrals there are only 2 terms which don't completely cancel, the terms coming from the integration of \sin^2(\theta) and \cos^2(\theta) which add up to \Gamma=-4\pi \vec{i}+8\pi \vec{j}. Adding up this yields 4\pi but how come I can just add those two component up? Because I integrated both parts to the same parameter?
The integrand is a dot product. If you compute the dot product of \mathbf{u}\cdot \mathbf{v} you should get a scalar, not a vector.
(u_1 \vec{\mathbf{i}} + u_2 \vec{\mathbf{j}}) \cdot (v_1 \vec{\mathbf{i}} + v_2 \vec{\mathbf{j}}) = u_1 v_1 + u_2 v_2
Everything else you did is fine. You just have extra \vec{\mathbf{i}}'s and \vec{\mathbf{j}} where there should be none.
ah I see, thanks! My vector algebra has become a bit rusty in the last years.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
