Civ eng problem-volume of solid-simpsons rule
  • Thread starter Thread starter debwaldy
The discussion centers on calculating the volume of a solid pedestal using Simpson's Rule, which the poster finds confusing due to a lack of prior exposure in their math course. They have successfully calculated the surface area as 244,636 mm² but seek guidance on applying Simpson's Rule for volume calculation. A suggestion is made to decompose the pedestal into simpler shapes like spheres, cylinders, or cubes to facilitate the calculation. The importance of understanding Simpson's Rule and setting up a proper function for the shape is emphasized. Overall, the thread highlights the need for clearer explanations and resources on applying Simpson's Rule in practical scenarios.
debwaldy
hi,so in tec graphics iv been asked to calculate the area and volume of a solid pedestal?have the area bit done but confused about how to calculate the volume.we were told to use simpsons rule but i just don't understand how to use this as it was not on our math course in school,so it is merely some vague formula in the logtables to me.any direction at all would be v appreciated
i have worked out that the surface area is 244636mm^2 or 2.44636*10^-1 m^2
just don't know!
Have you considered splittng up the pedestal into constituant solids.
Sphere, cylinder, cube.
Well, without knowing what this pedastal looks like, all I can say is, have you tried looking at what Simpson's Rule is? Wiki has a pretty good description here:
http://en.wikipedia.org/wiki/Simpson's_rule
If you can set up a function for the shape, it should be pretty cut and dry to calculate the volume based on the link above.
