Clarification needed on coloumbs law, inverse square law, potential
The discussion clarifies the relationship between electrical and gravitational laws, particularly focusing on electrical field strength and potential. Electrical field strength is defined as F/q, while at a distance r from a charge, it is represented as -kQ/r², with k being a constant. The confusion arises around the term "potential," which in electrical contexts refers specifically to electrical potential (measured in volts) rather than gravitational potential energy. The conversation also addresses how to calculate the upper limit of a gold nucleus's size based on the energy of an alpha particle approaching it, emphasizing the conversion of kinetic energy to electrical potential energy. Overall, the distinction between electrical potential and gravitational potential is crucial for understanding these concepts in physics.
thomas49th
I always try and think about the gravatational laws when thinking of the electrical ones:
Can I just confirm that
Electrical field strength in a uniform field = F/q (force per unit of charge)
A electrical field strength at distance r from the body is \frac{-kQ}{r^{2}}
where Q is the charge of the body and k = \frac{1}{4\pi E_{0}}
Electrical potential (I've been looking on wiki but what actually does this potential do) = -kM/r, where M is the of body that gives out the charge at a
F = \frac{-kQq}{r^{2}}
but like gravity is there a E = \frac{-kQq}{r} ?
I'm having a bit of a problem with potential. In exam questoins they keep referring to the electric potential then just 'the potential', but that would mean gravity wouldn't it, by default don't we say potential is GPE. The mark schemes have no mention of gravity...is my common sense playing up?
I know about potential wells (and thus why we define the attractive force as -, to show a body is bound or under the effect of another body)
The question I have shows a 8MeV alpha particle headnig towards a gold-197 nucleus and being turned back (distance of closet approach type thing). How would I go about calculating the upper limit on the size of the gold nucleus? First I'm guessing I need to find the energy of the alpha particle at point closet to the nucleus?? I would expect the answer to be ~ 10^{-14}
To address your question, the energy in Mev is an expression of the initial kinetic energy of the particle right? And to figure where that energy - hence its velocity is depleted and then reversed - where the kinetic energy converts to electrical potential energy - you need to examine where the change in potential energy is such that the work that goes into building that potential energy (of repulsion in this case) is equal to the energy the particle originally had.
For electrical potential it is expressed as the work to bring a particle from infinity (where it is 0) to the point of interest (if it is repulsive) and in the case where it is attractive (gravity is attractive too and hence is treated similarly), then it carries a negative sign, because the force involved over the distance needs to be used to resist the particle from wanting to accelerate nearer.
If the problem is one involving electrical charge, "the potential" is indeed referring to electrical potential (units are Volts or J/C), and not gravitational potential energy.
Yep, it's potential energy. Gravitational potential energy is
U = -\frac{GMm}{r}
and electrical potential energy is
U = -\frac{kQq}{r}
But electrical potential (as opposed to potential energy) is
V = -\frac{kQ}{r}
which is potential energy per unit charge. (That is, potential energy of a "test charge" per unit test charge) This is the same quantity you probably know as "voltage."
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
