Clarification on heat propagation
  • Context: Graduate
  • Thread starter Thread starter feynman137
    Heat Propagation
Heat propagation is governed by the diffusion equation, ∇²T = κ ∂T/∂t, which is deterministic and allows for both forward and backward integration in time. The discussion clarifies that while heat propagation is influenced by its present state, it does not violate the determinacy and reversibility of classical mechanics. The heat equation is causal and local in time, meaning knowledge of the system's state at a single past point is sufficient to determine future states. Additionally, temperature is a statistical quantity that reflects the mean energy of particles in a many-body system.
  • Understanding of the diffusion equation and its applications
  • Familiarity with classical mechanics principles
  • Knowledge of statistical mechanics and thermodynamics
  • Basic grasp of causal relationships in physical systems
  • Study the diffusion equation in detail, focusing on its applications in heat transfer
  • Explore the implications of causality in classical mechanics
  • Investigate Boltzmann's H theorem and its relation to thermodynamic arrows of time
  • Learn about the mathematical techniques for solving partial differential equations, particularly in thermal systems
Physicists, engineers, and students in thermodynamics or statistical mechanics who seek a deeper understanding of heat propagation and its foundational principles in classical mechanics.
feynman137
Could you possibly comment the following statement:
'Heat propagation is a semi-deterministic process in that its future is determined by its present but not by its past.'
Is heat propagation a violation of the determinacy and reversibility of the laws of classical mechanics? Thanks
Science news on Phys.org
I disagree with the statement. Heat propagation is governed by the diffusion equation, ∇2T = κ ∂T/∂t. This equation is deterministic and can be integrated backwards forwards in time just as easily. The true statement has to do with its stability. When integrating backwards in time, small perturbations will grow and dominate the solution.
Temperature itself is, seen from a fundamental point of view, a statistical quantity. It describes the part of the mean energy of a particle within a many-body system (fluid or solid) which is due to it's irregular motion in the local rest frame of the bulk medium.
The heat equation is, as any physical equation that describes the time evolution of systems, causal, i.e., it describes the evolution of a quantity (or several quantities if you have a coupled set of equations like Maxwell's Equations for electromagnetism), given the history of the quantity (or quantities) at times prior to the time in question. BTW: It is important to note that by definition, time is a directed quantity, i.e., the causality principle defines a "fundamental arrow of time", from which also other "arrows of time" may follow, e.g., the "thermodynamical arrow of time" according to Boltzmann's H theorem.
Very often, and for sure on the fundamental level, the equations are not only causal but even local in time, i.e., one doesn't have to know the whole history of the system prior to the time under consideration, but it is sufficient to know the state of the system at one point in time in the past. That's also true for the heat equation: If you know the temperature field at one point in time and appropriate boundary conditions, it provides a unique solution for the temperature field within the body at any later time.
  • · Replies 17 ·
  • · Replies 43 ·
