- 13,791
- 16,591
@NoahsArk - I said I'd draw Minkowski diagrams. Here's one in the rest frame of a rod that's ten light nanoseconds long (about ten feet):
The two red lines represent the ends of the rod, not moving in this frame. I've also shown two crosses at time ##t=0##, which represent a couple of firecrackers going off. Note that the rod is ten light nanoseconds long and the firecracker explosions are ten light nanoseconds apart.
Now here's the same thing in a frame where the rod is doing 0.6c.
The two red lines again represent the front and back of the rod. The crosses represent the firecrackers, and there's a thin diagonal line joining them for clarity. I've also added various dotted lines connecting events to axes, again for clarity.
You can immediately see that the rod has length contracted by a factor of ##\gamma=0.8## - just read off the horizontal distance between the red lines. You can also see that the firecrackers are further apart by a factor of ##1/\gamma=1.25##. And you can see that this isn't contradictory, it's just that the firecrackers went off at different times when the rod was in a different place, so the distance between them isn't the same as the length of the rod.
This is the mistake you make when you treat the Lorentz transforms as transforming distance: your process measured the distance between the flash at the front of the rod 7.5ns after the back passed the origin, and assumed that the back was at the origin.
