kelly0303
- Messages
- 573
- Reaction score
- 33
Hello! I am a bit confused by the reference frames used in derivations for rotational motion in classical mechanics (assume that there is no translation and the body rotates around a fixed point). As far as I understand there are two main frames used in the analysis: a lab frame, which is fixed (and inertial) and a body frame, which rotates with the body and hence it is not inertial. In the lab frame the moment of inertia tensor is a function of time, but in the body frame it is constant and for a proper choice it can be made diagonal. In such a diagonal case, the kinetic energy is given by: $$T = \frac{1}{2}(I_x\omega_x^2+I_y\omega_y^2+I_z\omega_z^2)$$ So I am confused about this expression. Given that we have only the diagonal terms of the inertia tensor, it means that we are in the body frame, so I assume that this formula is expressed in the body frame. But I am not sure I understand how can you have kinetic energy in the body frame, if the frame is rotating at the same time with the object. Isn't the object fixed relative to the body frame, hence the kinetic energy of the body is zero? Also, ##\omega_x, \omega_y, \omega_z## should be also in the body frame (I guess it doesn't make sense to multiply terms from the body frame with terms from the lab frame in the same equation). But, again, how can you have an angular velocity in the body frame, given that the object is rotating at the same time with the frame. For example, assume that one particle of the object is located on the x-axis in the body frame. That particle will obviously rotate with respect to the lab frame, but in the object frame it will still be on the x axis. So according to the body frame that particle is not moving, hence it has no kinetic energy and no angular velocity (and the same logic can be applied for all the particles forming the body). So I am sure I am missing something here, probably having to do with the definitions of the frames or with associating the variables to the right frames, but I am really confused. Can someone clarify this for me? Thank you!
