What is the solution to the classical string problem?
  • Thread starter Thread starter Loren Booda
    Classical String
The discussion revolves around a classical physics problem involving a flexible string partially on a frictionless table and partially hanging off the edge. The initial state of the string is in equilibrium, with the weight of the hanging portion balanced by the friction of the portion on the table. To determine how long it takes for the string to slip completely over the edge, an infinitesimal impulse may be required to initiate movement. The dynamics of the problem become complex due to the need for a differential equation that accounts for friction, which complicates the initial static conditions. The participants express uncertainty about the solution, particularly regarding the role of quantum mechanics and the specifics of friction in this idealized scenario.
Loren Booda
Classical "string" problem
My freshman physics class was given the following problem. I can't remember if it can be solved by classical physics alone, or else needs a quantum mechanical start:
Half of a perfectly flexible string of length L and negligible width lies straight and motionless on an exactly horizontal (to gravity) frictionless table, while the other half hangs freely from its edge. How much time transpires until the string slips completely over the edge?
There's probably a better way to do this, but I'd try this:
F_{\rm net} = m\ddot{x} = \frac{\frac{L}{2}+x}{L}mg
where x is the distance between the end of the rope on the table and its starting point. The net force on the rope is just the weight of the fraction of the rope that is hanging off the table. If you solve that differential equation and find the time when x = L/2, that should be the answer.
jamesrc,
Sorry, I think I misstated the problem. The weight of the hanging string is initially counterbalanced exactly by the friction of its other half lying on the table. How much time transpires until the string slips completely over the edge?
The system is in classical (albeit singular) equilibrium, but needs an infinitesimal impulse, perhaps quantal, to get started. Taking Q. M. into account, is there a standard answer to this problem or a distribution of possible times, given the minimum information needed?
Oh, I thought the table was frictionless and the rope was held until t = 0, when it was released. As it is now stated, I'm not sure how to go about solving the problem. It seems to me that the initial static equilibrium conditions will not help you solve the dynamics, since you know nothing about the kinetic friction characteristics (you would expect, for a Coulomb model of friction, that &mu;k < &mu;s). And since the rope is so idealized, I don't see how/why you could/would employ a more sophisticated friction model (well, maybe viscous, but I don't see a compelling reason to).
Anyway, once it starts (and it wouldn't matter how it started as long as it wasn't given an initial velocity), it should keep accelerating and should be solvable using differential equation similar to the one from my other post (with a friction term in there).
I guess in short, I don't know, so I'll defer to those who do and check into see how this develops.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
