Classifying second-order Partial differential equations
hellomrrobot
What does it mean when it says to classify the second-order partial differential? (See attached)
How would I get started?
Linear second order PDE's can, by a change of coordinates, be written in one of three (technically four, but one is degenerate) standard forms, called elliptic, parabolic, and hyperbolic equations. Any introductory PDE textbook should contain a description of these three types of equations. See e.g. http://www.math.psu.edu/tseng/class/Math251/Notes-PDE%20pt1.pdf
Likes hellomrrobot
Partial differential equations with constant coefficients can be so classified. If there are variable coefficients, the equation may change from "parabolic" to "hyperbolic" to "elliptic" depending on the value of the independent variables.
Likes Number Nine
HallsofIvy said:
Partial differential equations with constant coefficients can be so classified. If there are variable coefficients, the equation may change from "parabolic" to "hyperbolic" to "elliptic" depending on he value of the independent variables.
Good catch. Thanks.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
