Cleaning Rod lenses in optics equipment
The discussion revolves around cleaning rod lenses in optical equipment that has a narrow entrance slit. Participants explore various methods and tools for effectively removing dust particles from the lenses without disassembling the equipment, considering both practical and theoretical implications of their suggestions.
  • Experimental/applied
  • One participant inquires about handheld air/vacuum cleaning tools with thin nozzles suitable for penetrating the narrow slit to clean the lenses.
  • Another participant suggests using optical-grade wipes with appropriate liquid, cautioning against using isopropanol or acetone on front-surface coatings due to potential damage.
  • A third participant recommends a specific product from Thorlabs as a potential solution.
  • One participant shares their experience that air cans are ineffective due to the nozzle's diameter being too thick to fit into the slit, leading to dust dispersion instead of removal.
  • Another participant proposes removing the slits to clean the lenses with a dampened optical-grade tissue, emphasizing the importance of technique to avoid scratching.
  • One participant argues that accessing the lenses through the slit may be futile and suggests that a pressurized enclosure could prevent dust ingress.
  • A later reply explains that the lens module is part of a larger machine, which complicates cleaning in the field without disassembly, highlighting the need for a more practical solution.
Participants express differing views on the effectiveness of various cleaning methods and tools, with no consensus reached on the best approach to clean the lenses without disassembly. The discussion remains unresolved regarding the optimal cleaning technique.
Participants acknowledge limitations in accessing the lenses and the potential for dust to enter the enclosure from other parts of the machine, which complicates cleaning efforts. There are also concerns about the risks of damaging the lenses with improper cleaning methods.
xusmee
Hi,
We have an optical equipment that has a narrow entrance slit, on the other end of the narrow entrance slit two rod lenses are exposed. They are getting dirty for various reasons. Does anybody know of any handheld air/vacuum cleaning with thin nozzle that can penetrate the slit and even remove dust particles accumlated on the lenses?
Much appreciated...
Welcome to PhysicsForums!
Have you tried optical-grade wipes, along with an appropriate liquid? Lint-free t-shirt material may or may not work, but if it's expensive, and/or hard to replace, you should probably go with the optical-grade wipes. It absolutely has to be wet, otherwise, it may scratch.
CAVEAT: my only experience in this field is from undergrad physics labs, and in cleaning of my glass masks. Also, don't clean front-surface with isopropanol / acetone! Depending on how it was made (and they're usually sputtered / evaporated / CVD'd metal on glass), you might end up rubbing it off!
I would try this first:
http://www.thorlabs.com/thorProduct.cfm?partNumber=CA3
I already tried the air can technique but it seems that the nozzle is thicker in diameter and I can't insert it into the slit and thereby spray on the rod lenses.It seems i am just dispersing the dust around the area..Same is the problem with making physical contact w/ the lenses. It's hard to make physical contact without opening up the module. Would you know if a thinner nozzle is available w/ the dust can.
The slits should be removable. If possible remove the slits, then dampen the center of a optical grade lens tissue with few drops of high grade methyl alcohol. Drag the moist spot across the lens. Ideally the dry end of the tissue will adsorb the alcohol as you drag leaving the lens dry behind. Repeat until the lens is clean.
If you can't get to the lens it will be nearly impossible clean.
Yes, trying to get to the lenses through the slit is pointless.
It sounds like the lenses are in some kind of sealed-off enclosure. If that enclosure could be pressurized slightly, then dirt and dust would not get in there in the first place.
I'm also wondering, if the slit is the only way to get to the lenses, just how is all that dirt getting in there?
The module that contains the lens is part of a bigger module so there are various other sources of dust getting in there. Think of it like a machine and the module that contains the lens is small part of the machine. I can take the machine apart and clean the lenses with physical application but this is not so useful in the field or in hospitals wherever a field service tech has to do it. So i was thinking of some way in which we do not have to open the whole thing (getting it back together involves lot of production time+labor).
  • · Replies 0 ·
  • · Replies 19 ·
10K
  • · Replies 94 ·
14K
  • · Replies 65 ·
12K
