How Do You Test Coax Cable Assembly Characteristics Using a VNA and Smith Chart?
  • Thread starter Thread starter dnyberg2
    Cable Testing
To test coax cable assembly characteristics using a VNA and Smith Chart, S11 should be swept with the cable end open, shorted, and terminated to analyze loss, resistance, capacitance, and inductance. S21 provides loss data at the frequency of interest, while the characteristic impedance relates inductance and capacitance per unit length through the formula Z0 = √(L/C). For a 12" coax at 49 MHz, the input behaves inductively when the end is open, and the impedance can be calculated using the Smith Chart. The speed of electromagnetic wave propagation in the coax is influenced by the relative permittivity, which must be factored into calculations. Understanding these parameters is crucial for accurate testing and analysis of coax cable assemblies.
dnyberg2
I need to test a coax cable assy for loss, resistance (AC&DC?) capacitance and inductance? Using a VNA in smith chart mode, how is it done? Do I sweep the coax (S11) with the other end open, shorted and then terminated? I know sweeping S21 will give me the loss @ freq of interest. Its the capacitance and inductance I'm not sure about.
How long is your cable assembly, and at what frequencies do you need L and C?
For loss, assuming you know the characteristic impedance, you use the VNA and plot the S21 in rectangular form with the correct termination. You see the signal attenuate with frequency. From that, you find the attenuation constant \alpha\; and back calculate.
There are 5 diff lengths 3.5, 5.5, 6.5, 9 & 12" all at 49 MHz.
Are you asking about the inductance or capacitance at the input of the coax when the end is open or shorted? That's totally different from the inherent L and C. The characteristic L and C is governed by
Z_0=\sqrt{\frac L C}
Where Z0 is the characteristic impedance, L and C is the inductance and capacitance per unit length.
If you are asking whether the input is inductive or capacitive of the coax at different length at 49MHz when the end is open, then it's a different story. For 49MHz, let's assume εr=4, this mean the speed of the EM wave propagates through the coax is about half of light which is 1.5EE8 m/sec. For 49MHz, the wavelength λ≈118"
Your longest coax is 12", it is only 1/10 λ. This is way smaller than λ/4. The input is inductance if the end is open. You can find the impedance by using the Smith Chart and then use 49MHz to back calculate the inductance.
The number I used is assume εr=4, you have to do the calculation with the number for your coax. The speed of the EM propagation is
V_p= \frac 1 {\sqrt{ε_0 ε_r μ}} \; , \; λ= \frac {V_p}{49\times 10^6}
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
