Coefficient of static friction in a 3D Games Engine
The discussion focuses on analyzing the physics of the Source video game engine by comparing the behavior of different materials on an inclined platform. The coefficient of static friction is calculated using the equation μ = tan(theta), where theta is the angle at which each block begins to slide. Participants confirm that this method is appropriate for measuring static friction and emphasize the importance of recording the angle accurately as the incline is gradually increased. The relationship between the angle and the coefficient of static friction is highlighted, indicating that materials with higher coefficients will slip at greater angles. Overall, the experiment aims to provide meaningful insights into the physics of friction within the game engine.
Danilov22
For a personal project, I am analysing the physics in the Source video game engine and comparing it with real life.
I have set up in the engine a platform which increases in inclination from 0 to around 70 degrees.
On this platform there are four, equally weighted cubes each with a different material property: slime, ice, wood, and rubber. The weights of the cubes are modifiable and the angle of the platform is measurable.
I have been told to use the coefficient of static friction equation. This is listed in "Physics" by Jim Breithaupt (1999, Macmillan Press, ISBN: 0333733028) as:
μ = W sin theta / W cos theta
Is this correct and relevant to my needs? Does this take into consideration the material properties of the blocks? How can I use the results in a meaningful manner?
Additional:
I have been told that this experiment can be used with the equations:
sin theta * gravity * mass = pulling along force
cos theta * gravity * mass = pulling down onto surface force
Any explanation into this would be greatly appreciated,
Kind regards,
Danilo Vujevic.
Science news on Phys.org
All that is saying is that 100% of the gravitational force is pulling against the surface when there is no angle. cos(0) = 1
If the angle is 90 degrees, cos(90) = 0, 0% of the gravitational force is pulling against the surface.
cos(45) = 1/2, so at a 45 degree angle half of the gravitational force is working to move the object along the board, and the other half is working to increase the friction.
So as you increase the angle you increase the force (and decrease the friction), the lower the static friction coefficient the sooner the object will break free of it's standing position.
(mg)cos(theta) < C * (mg)sin(theta) while the object is not moving.
Where C is the coefficient you are looking for. I think that's right.
It is correct for a non accelerating incline, and since the W cancels out, u_s =sin theta/cos theta, which further simplifies to u_s = tan theta. Theta is the angle of the incline with respect to the horizontal. As the incline is slowly raised, the block will just start to slip at a certain angle. Record that angle, and calculate u_s as the tangent of that angle. As noted above, the material with the higher coeficient of static friction will slip at a greater angle.
Additional:
Kind regards,
Danilo Vujevic.
These equations are just part of the solution..Newton's first law provides the other equations which lead to u_s =tan theta.
Firstly, thanks a lot for the rapid responses!
So for my experiment where the incline slowly increases linearly, I should just record the angle at when the different types of blocks begin to slide?
For example, the ice block begins to slide at 5 degrees.
u_s = tan theta
u_s = tan 5
u_s = 0.087
Therefore the coefficient of static friction for ice in the game engine is 0.087. Is this correct?
Yes, be sure to raise the ramp slowly and smoothly, and repeat the experiment several times to get an average value of the angle when they just start to slide (don't overshoot the angle). You should probably round off the answer to 2 decimal points, depending on the accuracy of your measurement of the angle.
PhanthomJay said:
Record that angle, and calculate u_s as the tangent of that angle. .
Isn't it the cotangent of the angle of incline? See my equation above.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
