Coin Rolling Problem: Find Speed to Stay Upright
  • Thread starter VortexLattice
  • Tags
    Rolling
This is the same result you obtained in your attempt using the Virial Theorem, but with a more rigorous approach. It is important to note that this solution depends on the coin rolling on a circular path, which may not always be the case. However, for the given assumptions, this is a reasonable solution.In summary, the speed at which the coin should roll to stay upright is v = Ω a^2/2r, where Ω is the rotational velocity of the coin, a is the radius of the coin, and r is the radius of the circular path it is rolling on. This solution takes into account the forces of
VortexLattice
146
At what speed should a coin of radius a and mass m roll to stay upright? Assume the coin is uniform, a thin disk, almost upright, and rolling on a perfectly rough horizontal surface, on the surface of the earth.
I've found a solution using the Virial Theorem, but I really don't buy it. It just uses the potential energy of the coin (mga, because it's almost upright) and the kinetic energy from the rolling (both translational and rotational) and relates them, allowing you to find v. That doesn't seem quite right to me for some reason, though:
[itex]\omega = v/a[/itex]
[itex]I = ma^2/2[/itex]
[itex]T = mv^2/2 + I\omega^2/2 = mv^2/2 + mv^2/4 = 3mv^2/4[/itex]
[itex]V = mga[/itex] (since θ is essentially 0)
[itex]V \propto r^1[/itex]
→[itex]2<T> = 1<V> \rightarrow v^2 = (2g/3a) \rightarrow v = \sqrt{2g/3a}[/itex]
Seems sketchy to me, this just doesn't seem like a legitimate use for the virial theorem.Anyway, I know there must be a good solution for this using actual mechanics. Here's a free body diagram with some other details:
Here's what I've got so far, but there are a lot of as yet unjustified assumptions. I'm pretty sure it has to be rolling in the arc of a circular path. If it wasn't, it seems like there would be absolutely nothing just stopping it from falling down from gravity as it rolls.
So, I realized that since the coin is spinning as it's going around, if we look in the frame moving with the coin, there's a coriolis force:
[itex]\vec F_c = -2\vec \Omega \times \vec v[/itex]
Where Ω is the rotational velocity of the frame and v is the velocity of a point on the disk. Because the ground is "perfectly rough", we can treat the point where the coin's touching the ground as not slipping with respect to the axis (that the arc is around) it's rolling around. So, that point is an axis the coin can "rotate around". Due to the coriolis force, there should be a force on the top and bottom sides of the coin (because their velocities are in opposite directions), of the same magnitude. However, because the bottom of the coin has a shorter lever arm, its torque is less.
Thus, the equilibrium condition I get is
[itex]\tau_t = \tau_b + \tau_g[/itex]
The problem is, [itex]\tau_g = mga sin(\theta)[/itex] where θ is the very small angle between the coin and the vertical. Also, there's still the radius of the coin's path from its axis in this equation. The way I got around this was by saying that a perpendicular line drawn from the center of the coin to the ground hits the spot it's rotating around, giving me the relation [itex]sin(\theta) = a/r[/itex], which cancels both r and θ. However, I don't see any reason why this should necessarily be the case...it seems like the coin could theoretically be almost flat to the ground but going in a path with a fairly large radius.
Does my solution sound right? Can anyone enlighten me?
Thanks!
Thank you for your interesting question about the speed at which a coin of radius a and mass m should roll to stay upright. I would like to provide a more thorough and rigorous solution to this problem.
First, let us consider the forces acting on the coin. As you correctly mentioned, there are three forces at play: the gravitational force (mg), the normal force from the ground (N), and the coriolis force (Fc). The normal force is perpendicular to the surface of the ground and balances out the component of the gravitational force that is perpendicular to the ground. The coriolis force, as you mentioned, is due to the rotation of the coin and acts in the opposite direction of the motion of the coin.
Now, let's look at the torque equation you have set up. The torque from the gravitational force is indeed mga sin(θ), where θ is the small angle between the coin and the vertical. However, the torque from the coriolis force is not simply Fc times the radius. The coriolis force is not acting at a single point on the coin, but rather at all points along the coin's radius. Therefore, we must consider the torque from the coriolis force as the sum of the torques from all these individual forces, which can be calculated using the perpendicular distance from the axis of rotation to each point on the coin. This distance will vary depending on the angle θ, making the calculation more complicated.
To simplify this problem, we can consider the coin to be rolling on a circular path with a constant radius r. This is a reasonable assumption since the coin is rolling on a perfectly rough surface. In this case, the torque from the coriolis force can be calculated as Fc times the radius r. This simplification is similar to your approach of using the perpendicular distance from the center of the coin to the ground, but it takes into account the varying angle θ.
Now, we can set up the equilibrium condition as follows:
τ_g + τ_c = 0
mga sin(θ) + Fc r = 0
mga sin(θ) - 2mΩv = 0
mga sin(θ) - 2mΩ(v/a) = 0 (since ω = v/a)
We can then solve for the velocity v:
v = aΩ/2 sin(θ)
Related to Coin Rolling Problem: Find Speed to Stay Upright
1. What is the coin rolling problem?
The coin rolling problem is a classic physics problem that involves a coin rolling down an incline and trying to determine the minimum speed it needs to maintain in order to stay upright.
2. What factors affect the speed needed to keep the coin upright?
The speed needed to keep the coin upright is affected by several factors, including the mass and size of the coin, the angle of the incline, and the coefficient of friction between the coin and the surface it is rolling on.
3. How is the minimum speed to stay upright calculated?
The minimum speed to stay upright can be calculated using the formula v = √(rgtanθ), where v is the speed, g is the gravitational acceleration, r is the radius of the coin, and θ is the angle of the incline.
4. What happens if the speed is below the minimum required?
If the speed is below the minimum required, the coin will not be able to maintain its balance and will eventually start to roll back down the incline.
5. How does this problem relate to real-world scenarios?
This problem has applications in various fields such as robotics, physics, and engineering. For example, it can help in designing robots that can maintain their balance while moving on uneven surfaces, or in understanding the physics behind the rolling of objects on hills or ramps.
