AP Calc Project: Find Dimensions of 12 Fl. Oz. Cola Can
  • Thread starter Thread starter Vigo
    Project
Vigo
In my AP Caluculus class we are on the chapter of derivative applications and we have this project to di.
A right circular cylinder is to be designed to hold 12 fluid ounces of a soft drink and to use a minimum amount of material in construction. Find the required dimensions for the container. (1 fl. oz. = 1.80469 inches cubed)
If someone could please help to get me started on this problem I would be very grateful.
\text{SA}=2\pi r\left(h+r\right)
\text{V}=\pi r^{2}h=12
I suggest you find an expression for h in terms of r in the second and plug it into the first to simplify. The rest should be easy assuming you know how to optimize a function using differential calculus.
Translate the problem into a mathematical problem.
You want to minimize the surface area of a cylinder under the constraint that the volume must be some given volume V.
So start by drawing a picture. Introduce variables that will be important (height, radius, suface area). And relations between them. This is the given. What is the unknown?
OK so:
h = 12/(pi*r^2)
and
f(x) = (2*pi*r)*(12/pi*r^2) + 2(pi*r^2)
Find the derivative of f(x) and set that equal to 0.
Is all of this right?
If it is, what does the final answer tell you?
And where does the 1 fl. oz. = 1.80469 inches cubed come into this problem?
Thanks again.
Okay, so f is the surface area of the can as a function of the radius r (not x!). You can minimize this using whatever knowlegde you have of calculus (=yes, differentiating would be the standard procedure).
The "1 fl. oz. = 1.80469 inches cubed" comes from the conversion from some archaic unit such as fluid ounce to another one, namely the inch^3. You should use whatever dimensions you are comfy with and do the proper conversion.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
