Undergrad Collision in special relativity
The forum discussion centers on the analysis of inelastic collisions in the context of special relativity, specifically involving two masses, m1 and m2, where m2 is a multiple of m1 (m2 = k * m1). The calculations demonstrate that the thermal energy generated during the collision contributes to the rest mass of the resultant object. Key equations derived include conservation of momentum and energy, leading to expressions for the change in work (ΔW) that depend on the mass ratio and velocities involved. The discussion emphasizes the importance of including thermal energy as part of the rest mass in relativistic collisions.
  • Understanding of special relativity principles, including energy and momentum conservation.
  • Familiarity with relativistic mass (γ) and its implications in collision scenarios.
  • Knowledge of inelastic collisions and their characteristics in physics.
  • Basic mathematical skills for manipulating equations involving mass and velocity.
  • Study the derivation of relativistic momentum and energy equations in detail.
  • Learn about the concept of invariant mass and its application in collision problems.
  • Explore the relationship between thermal energy and rest mass in relativistic contexts.
  • Investigate advanced topics in special relativity, such as the implications of high mass ratios in collisions.
Physicists, students of theoretical physics, and anyone interested in the complexities of relativistic mechanics and energy transformations during collisions.
exponent137
Let us assume that we have inelastic collision of masses ##m_1=1## and ##m_2=k##
This means ##m_2=k m_1##.
(##k>>1##)
##v_1=v##, ##v_2=0##, Velocity after collision is ##v'##.
Units are such that ##c=1##. Let us assume that ##v_1## is close to one.
At inelastic collision we respect conservation of energy and momentum. I assume that non-kinetic energy go to thermal energy.
If the moving body is much less massive than rest body, my calculation gives:
##\Delta W=\gamma (1-v/v') +k##
##\Delta W\approx \gamma-\gamma'\approx\gamma-1##
Let us assume that speed after collision is small.
If the moving body is much more massive than rest body,
##m_1=k## and ##m_2=1##
##\Delta W=k\gamma (1-v/v') +1## and it follows:
##\Delta W\approx 1##
This means that in the rest system of the small body (before collision) we see much smaller thermal energy than in the rest system of the larger body (before collision.)
I do not understand, how to explain this.
I assume you mean the velocity, in the original frame, of the single object that exists after the collision?
It goes into the rest mass of the single object that exists after the collision; "thermal energy" is part of rest mass. You can't get things right if you don't include that. I don't see it anywhere in your equations; I would suggest reposting your analysis with all masses explicitly included. Trying to separate out kinetic energy from rest energy is usually not worthwhile in relativity, and often leads to errors.
Likes exponent137
Yes, in the original frame of the single object that exists after the collision.
I did not separate kinetic energy from rest energy. But, yes, I think that thermal energy is part of rest mass, but I do not know how to include this?
Let us assume that the moving mass is the smaller one , (##m_1##), and ##m_2/m_1=k##. We are in the frame, where ##m_2## is at rest.
My derivation was:
conservation of momentum:
##m_1\gamma_1 v_1=(m_1+m_2)\gamma'v'##
##m_1\gamma_1 v_1=m_1(1+k)\gamma'v'##
conservation of energy:
##m_1\gamma_1+m_2=(m_1+m_2)\gamma'+\Delta W##
The result is
##\Delta W/m_1 =\gamma_1 (1-v_1/v')+k##
I do not know how to better include ##\Delta W## as the part of the rest mass?
##v'## is much smaller than ##v_1##.
The other option is:
Let us assume that moving mass is the larger one (##m_2##) and ##m_2/m_1=k##. We are in the frame, where ##m_1## is at rest.
My derivation was:
##m_2\gamma_1 v_1=(m_1+m_2)\gamma'v'##
##m_1 k \gamma_1 v_1=m_1(1+k)\gamma'v'##
##m_2\gamma_1+m_1=(m_1+m_2)\gamma'+\Delta W##
The result is
##\Delta W/m_1 =k \gamma_1 (1-v_1/v')+1##
##v'## is almost the same as ##v_1##, and both a little smaller than 1.
And so on. But in the rest sistem of ##m_1## the result is not the same as in the rest system of the ##m_2##.
Why?
You are postulating incorrectly that which should be derived.
Using m1, m2 for the initial masses, you must treat the result mass M as something to derive from conservation. In all cases, I refer to invariant masses. Then, you have, for your set up:
m1 γ1 v1 = M γ' v' for momentum, and
m1 γ1 + m2 = M γ' for energy.
You have to solve for M. When doing approximations for high mass ratio, you need to be careful keep enough terms for significance in the final result, because M will differ only by a tiny amount from m1 + m2. If you do it right, all works out. For example, for γ = 2, m1 = .01, m2 = 1 and then with interchange of m1 and m2, you get M = 1.01985 either way. This tells you that .00985 of the mass of the resultant object is thermal.
Likes exponent137
Closing the circle on the OP, I provide a few more hints on how to exploit high mass ration for approximation in a correct way.
A key technique to know is that if you have a problem involving energy and momentum, it is almost always better to use those as your variables rather than gamma and velocity. A few key relations are (continuing with c=1):
E2 = P2 + m2, or E2 - P2 = m2
and E/m = γ.
Then the description of this problem becomes simply:
E1 + m2 = E'
P1 = P'
Solving for M is trivial: M2 = (E1 + m2)2 - P12
From here, one limiting cases is E1, P1 << m2. If you drop squares of 'smalls', use common approximations for square roots and quotients, you get:
M ≈ m2 + m1 γ1
while if you assume m2 is very small compared to the other quantities, you end up with:
M ≈ m1 + m2 γ1
equivalent as expected. Whichever frame you use, the result is saying (in the high mass ratio limit) all of the KE of the smaller body relative to the larger body is added as thermal energy to the combined object, contributing to its mass.
Likes exponent137, Nugatory and PeterDonis
I will calculate the case with ##m_2## is small, (small mass is in rest at the start) that you will see that I understand:
M^2=E_1^2+2E_1m_2+m_2^2-(E_1v_1)^2=E_1^2/\gamma_1^2+2E_1m_2+m_2^2
=m_1^2+2m_1\gamma_1 m_2+m_2^2
If we drop ##m_2^2## and we make approximate square root we obtain your last equation.
Thanks for help.
I will add still the case, where the ##m_2>>m_1## and ##m_1## is moving and ##m_2## is at rest.
The result is the same as above, because in both cases the same mass is moving, ##m_1##, and the same mass is at rest, ##m_2##, and the velocity is the same. It is not important that their values are swaped. The result is symmetric according to ##m_1## and ##m_2##, so this symmetry is the key, that the termal energy is the same in our both cases.
If we drop ##m_1^2## and we make approximate square root we obtain Pallen's eq. before his last equation.
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 36 ·
  • · Replies 67 ·
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 30 ·
  • · Replies 32 ·
