Combinatorics-binomial expansion?
  • Thread starter Thread starter pupeye11
    Expansion
44 replies · 6K views · last reply
No, because, for example, the x2 term in A(x) and the x3 term in B(x) will combine to contribute to the x5 term in A(x)B(x).
By the way, don't you see a contradiction in the answer you just gave, [itex]126y^4[/itex], and the formula you verified earlier, which is a sum of a bunch of terms?
Yeah, I forgot about the sum... But if I was working with just B(x) then my answer would be [tex]126y^4[/tex] but since I have A(x) I need to multiply together. Is there a theorem in combinatorics that makes this easy or do I just need to do it the long way?
Well, there's the formula you verified earlier.
That is kind of the problem, I get that if I use the formula I'll have something that looks like this
[tex]\sum_{k>=0}(\sum_{i=0}^{k}a_{1}b_{4})x^5[/tex]. How does this give me a number for a coefficient? Or do I take the coefficient at [tex]a_{1}[/tex] and [tex]b_{4}[/tex] and multiply them together. Then after doing that for all the combinations that create x^5 do I add them all together?
How did you get this
from this
pupeye11 said:
A(X)B(X) = [tex]\sum_{k>=0}(\sum_{i=0}a_{i}b_{k-i})x^k[/tex]
The second sum sign in the answer should be from i=0 to k.
Yes, that came from the one you just copied and put above.
I'm asking how you got the first from the second because they're inconsistent.
Expand this summation for k=5:
[tex]\sum_{i=0}^k a_i b_{k-i}[/tex]
What do you get?
[tex]a_{0}b_{5}+a_{1}b_{4}+a_{2}b_{3}+a_{3}b_{2}+a_{4}b_{1}+a_{5}b_{0}[/tex]
Right, and that sum of six terms is the coefficient of the x5 term in A(x)B(x). In this case, all the ai's are equal to 1. What are bi's equal to?
The [tex]b_{i}'s[/tex] are going to be [tex]b_{5}=nCr(9,5), b_{4}=nCr(9,4),b_{3}=nCr(9,3),b_{2}=nCr(9,2),b_{1}=nCr(9,1),b_{0}=nCr(9,0)[/tex]?
Not quite. Remember, the coefficient of xk includes everything that multiplies xk when you expand (x+y)9.
Are you trying to say I need the corresponding y's in there too, like b5 would have a y^4 and b4 would have a y^5, so on so forth? Otherwise I am not following you on this one.
Alright so the answer will be [tex]nCr(9,5)y^4+nCr(9,4)y^5+nCr(9,3)y^6+nCr(9,2)y^7+nCr(9,1)y^8+nCr(9,0)y^9[/tex] right? and thank you for all your help!
Yup, that's it. Good work!
