Probability of No Rook Capture on 8x8 Chessboard | Combinatorics Solution
  • Thread starter Thread starter mcafej
    Combinatorics
The probability of placing 8 rooks on an 8x8 chessboard without them being able to capture each other is calculated as 8! divided by the number of ways to choose 8 squares from 64 (64 choose 8). This approach ensures that each rook occupies a unique row and column, with the first row offering 8 choices, the second 7, and so on down to 1. The resulting probability appears quite small, reflecting the limited configurations that meet the criteria. The calculation is confirmed as correct by peers in the discussion. Understanding this combinatorial problem is essential for mastering chess probability concepts.
mcafej
I'm just checking my work on this. Given an 8x8 chessboard, you randomly place 8 rooks on the board. What is the probability that no rooks can capture another one. In other words, probability that no 2 rooks are in the same row or column.
My solution is simply 8!/(64 choose 8), but that seems like a really small probability. My reasoning behind it is that if you look row by row, in order for 8 rooks to not be able to capture each other, there must only be 1 rook in each row, so if you look at the first row, you have 8 possible choices to put a rook. Then if you look at the next row down, there are only 7 possibilities (because the 8th square on that row would put hat rook in line with the 1st rook), then for the 3rd row there are 6 possible choices, and so on all the way down to 1. So that is all the ways that no two rooks would capture each other, and there are a total of 64 Choose 8 ways to put the rooks on the board.
I'm just double checking my work because I'm studying for a test.
Your answer looks right to me. You could check it by trying a mini chessboard.
Sounds right to me.
