Combining Equations: How to Combine Fc=mv²/r and Fg=qvb?
  • Thread starter Thread starter music_lover12
To combine the equations Fc=mv²/r and Fg=qvb, it's important to clarify the variables involved. The first equation can be rearranged to express v as v=Fg/qB. Substituting this expression for v into the first equation leads to Fc=m(Fg/qB)²/r. The correct form for mass m after rearranging is m=Fcr*(qB/Fg)², ensuring to include the squares for q and B. This substitution and rearrangement yield the desired relationship between the variables.
music_lover12
How do I combine these two equations?
Fc=mv(squared)/r
Fg=qvb
You need to make an effort yourself, and furthermore, defined your symbols. For example, on the LHS of each equation, you have Fc and Fg, respectively. Are these Fxc and Fxg, or are they different variables Fc and Fg?
It is with the smaller c and g.
Well, in that case, can you rearrange the second equation to get it into the form v=... ?
Yeah, it would be v=f/qB...
...also I'm trying to combine the two equations to find m, which is mass.
Ok, so you now have Fc=mv2/r and v=Fg/qB. Now, can you substitute the second equation into the first? [i.e. replace v^2 in the first with Fg/qb]
Right, well if you manage to do the substitution above, then you need to rearrange the equation you obtain to get it in the form m=...
Okay, so I substituted the second equation into the first and I got Fc=m*fg/qB/R. Is that right?
No, v is squared in the first equation, and thus substituting the second into the first should yield F_c=\frac{m}{r}\left(\frac{F_g}{qB}\right)^2. Can you rearrange this?
m=Fcr*qB/Fg^2 :rolleyes:
Well, you're missing a square on q and B; adding parentheses like this m=Fcr*(qB/Fg)^2 gives the correct solution.
Oh okay. I see. Thank you very much!
You're welcome.
