Common ion effect and temperature
In summary, the extent of dissociation of a weak acid is influenced by the concentration of the common ion already in the solution.
qwerty1232
23
I have been researching extensively, but am unable to find if the extent of the common ion effect is influenced by the concentration of the common ion already in the solution? For example, if there are two solutions of weak acid which have dissociated to a different extent, would the addition of more H+ affect the one that is less dissociated more substantially than the one with many H+ already in solution?
I was wondering if it was like the entropy change at various temperature - if the temperature is high, the change in entropy will have less of an effect.
Chemistry news on Phys.org
In general common ion effect is only a rule of thumb. System always proceeds to equilibrium, so that the reaction quotient equals equilibrium constant.
Why are these solutions dissociated to different extent? They must be different for that, so you can directly compare them.
The extent of dissociation of a weak acid might be different at different temperatures. So if the same concentration of strong acid was added to solutions with different concentration of H+ already, would there by any difference in the extent to which the reverse reaction proceeds (to restore equilibrium due to common ion effect)?
Try to calculate it, it is not that hard. You will have to define what you mean by the reaction extent.
Please note that - as I signaled earlier - it doesn't make much sense to analyze complex system with a thumb rules. That's the easiest way of getting wrong answers, as in most cases thumb rules work only in some conditions are meet.
Seems to me it depends a lot on what you mean by "affect more", that is vague. For example, do you mean will it have a larger percentage effect? If so, relative to what? In any case, as Borek said, it is easy enough to calculate, particularly if you keep the amount of added acid small.
Do you mean calculate it by working out the ka? This is what I have been trying to do, but unfortunately cannot due to having so many chemicals in the solution (we were performing a titration).
Basically, we were titrating NaOCl to find the concentration of HOCl/OCl- at various temperatures, and sulfuric acid was added in order to catalyze the oxidation of these (by I-). What I would like to know is if the solution which was less dissociated (cooler temperature) would have been more likely to reform HOCl than the solution which was more dissociated?
Does that make sense?
You should assume Ka is known.
I still don't know what the experiment is, but I have again a felling that you are investigating things that are unrelated to the real problem. Hypochlorous acid is so weak it will be dissociated in about 10-3% at pH 2 - and if memory serves me well your pH is even lower than that.
The experiment is basically to find the ka of HOCl at various temperatures. However, we've been unable to find each of the concentrations separately, so have just used a pH meter to investigate the extent of dissociation. However, the change in pH was fairly substantial as temperature increased (from about pH0.7-0.3 as temperature increased from 8C to 40C). I am just trying to work out why the change was large, and how to relate this to ka.
I really appreciate all your help in answering all my questions. Please trust me when I say I have not tried to find these answers everywhere myself.
If you have any more ideas, they would be greatly appreciated. Many thanks again.
1. What is the common ion effect?
The common ion effect is a phenomenon that occurs when a solution contains two or more ions that have a common ion. This leads to a decrease in the solubility of a substance due to the presence of the common ion.
2. How does the common ion effect affect solubility?
The common ion effect decreases the solubility of a substance by increasing the concentration of one of the ions in the solution. This causes a shift in the equilibrium of the solution, leading to a decrease in the solubility of the substance.
3. What factors influence the common ion effect?
The common ion effect is influenced by the concentration of the common ion, the solubility product of the substance, and the temperature of the solution. Higher concentrations of the common ion and lower solubility products result in a more significant impact on the solubility of the substance.
4. How does temperature affect the common ion effect?
The common ion effect is also influenced by temperature. Generally, an increase in temperature leads to an increase in the solubility of a substance. However, in the case of the common ion effect, an increase in temperature can decrease the solubility due to the shift in equilibrium caused by the increased ion concentration.
5. What is an example of the common ion effect in real life?
An example of the common ion effect can be seen in the solubility of calcium phosphate in milk. Milk contains a high concentration of calcium ions, which can decrease the solubility of calcium phosphate, leading to the formation of lumps in milk that is heated at high temperatures.
  • Chemistry
