Common Reference OSC for test equipment
The discussion centers on the advantages of using a single lab-quality 10 MHz oscillator (OSC) as a reference for multiple bench equipment inputs. It highlights the cost-effectiveness of this approach compared to purchasing individual oscillators for each device. The conversation also touches on the use of GPS-synchronized 10 MHz OSCs, emphasizing that they are only necessary for applications requiring high accuracy. A practical example illustrates the efficiency gained by using a common cesium reference for tuning a 14 MHz oscillator, significantly reducing production bottlenecks.
  • Understanding of 10 MHz oscillators and their applications
  • Familiarity with cesium reference oscillators
  • Knowledge of audio analyzers and their frequency measurement techniques
  • Experience with signal generators and frequency mixing
  • Research the specifications and applications of cesium reference oscillators
  • Explore the differences between frequency counters and audio analyzers in frequency measurement
  • Learn about the implementation of GPS-synchronized oscillators in precision applications
  • Investigate techniques for frequency mixing and its role in signal processing
Electronics engineers, test equipment designers, and professionals involved in precision frequency measurement and calibration processes.
dnyberg2
Can someone please explain to me what if any is the benefit in using one lab quality 10 MHz OSC to run all your bench equipment ref OSC inputs? And, what about this GPS thing? Why use an expensive GPS synced 10 Mhz OSC source to drive your test bench?
Thanks
1 is Cheaper than buying ten?
Don't use GPS unless you need the accuracy?
Am I missing something?
At one time I wrote programs to test cellular phone circuit boards. One board had a 14 MHz oscillator that had to be tuned to +/-0.1 Hz. Using a frequency counter that meant tuning to within +/-1 Hz and then switching the frequency counter to 0.1 Hz precision which required 10 seconds per measurement to further tune to the 0.1 Hz requirement. Can you imagine how much time that took? This step was a real bottleneck in production.
Since all of our test equipment was tied to the same 10 MHz cesium reference, I was able to use a signal generator to mix the 14 MHz oscillator down to 300 Hz and use an audio analyzer to measure the 300 Hz. Audio analyzers use a different method to measure frequency than frequency counters. Audio analyzers count the number of 10 MHz cycles between zero crossings to calculate the frequency. The analyzer gave me a frequency reading accurate to 0.01 Hz, 300 times per second. This would have been impossible if both the signal generator and the audio analyzer hadn't been tied to the same reference.
  • · Replies 16 ·
  • · Replies 30 ·
