Comparing QM/MM and QM/MD: What's the Difference?
  • Thread starter Thread starter greisen
    Difference
The discussion revolves around the differences between the computational methods QM/MM (Quantum Mechanics/Molecular Mechanics) and QM/MD (Quantum Mechanics/Molecular Dynamics). Participants explore the theoretical underpinnings and applications of these methods in computational chemistry.
  • One participant seeks clarification on the differences between QM/MM and QM/MD, presuming that QM/MM converges to a structure based on gradient tolerance.
  • Another participant confirms the definitions of QM, MM, and MD, indicating a shared understanding of the terms involved.
  • A further contribution suggests that in QM/MD, the structure may deform to an energy-minimized transition state rather than a ground state, proposing that multiple energy-minimized geometries could lead to this transition state.
  • This participant references a source that describes the use of molecular dynamics for simulating molecular motion and calculating relative populations of various conformations, highlighting the role of MM in these calculations.
Participants do not reach a consensus on the specifics of the differences between QM/MM and QM/MD, and multiple competing views regarding their applications and implications remain present.
The discussion does not resolve the assumptions regarding the convergence behaviors of QM/MM and QM/MD, nor does it clarify the specific conditions under which each method is most applicable.
greisen
Hi all,
I have a general questions on which is the difference between these two methods QM/MM and QM/MD?
Any hints appreciated - thanks in advance
Best
QM = quantum mechanical?
MM = molecular mechanics?
MD = molecular dynamics?
Is this what you are talking about?
Yes - that is my question.
I would presume that in a QM/MM one would converge to structure when the QM part would converge due to some gradient tolerance but I am not quite sure about the QM/MD.
Any advise appreciated - thanks
Perhaps in the MD system, the structure is allowed to deform to an energy minimized trasition state (by MM) rather than to a ground state energy minimized structure. The path to that transition state will contain multiple energy minimized geometries. Those structures leading to the transition state could be calculated with MM resulting in the eventual geometry of the transition state. Perhaps the overall process using MM calculations for ground state, intermediate and transition state structures would collectively be referred to as molecular dynamics? A quote from "Computational Chemistry" by Errol Lewars:
Programs like those in AMBER are used not only for calculating geometries and energies, but also for simulating molecular motion, i.e. for molecular dynamics, and for calculating the relative populations of various conformations or other geometric arrrangements (e.g. solvent molecule distribution around a macromolecule in Monte Carlo simulations. In molecular dynamics Newton's laws of motion are applied to molecules moving in a MM forcefield, although relatively small parts of the system (system: with biological molecules in particular modelling is often done not on an isolated molecule but on a molecule and its environment of solvent and ions) may be simulated with quantum mechanical methods. In Monte Carlo methods random numbers decide how atoms or molecules are moved to generate new conformations or geometric arrangements (states) which are then accepted or rejected according to some filter. Tens of thousands (or more) of states are generated, and the energy of each is calculated by MM, generating a Boltzmann distrubution.
  • · Replies 70 ·
  • Poll Poll
  • · Replies 41 ·
