Comparison between CFD results and experimental data
The discussion centers on the challenges of comparing CFD results from a RANS simulation of methane and air jets to existing experimental data primarily focused on water jets. It highlights that while matching Reynolds numbers may seem sufficient, the behavior of different fluids in jets can vary significantly, making direct comparisons problematic. The importance of proper model validation in CFD is emphasized, noting that turbulence models may fail to predict key jet properties accurately. Additionally, it is suggested that measurements from reacting flows should be used once combustion is involved. The conversation underscores the complexity of fluid dynamics and the need for careful consideration when validating simulations against experimental data.
exergetic
Hi everybody,
my question is not properly about CFD but mainly about Fluid Dynamics itself. I have performed a RANS simulation of a round jet of methane and air and now I'd like to compare those results to some experiments. Unfortunately there aren't papers about experimental data for methane/air jets but mainly I'm finding a lot of data about round jets of water with different nozzle dimensions. So my question is: can I compare those experimental data with my results if the Reynolds number are the same? Or is it highly incorrect?
Thank you guys!
I don't believe that would be a good comparison. Unfortunately, this is the most troubling aspect of CFD: model validation.
A water jet in air will behave different from a water jet in water. An air jet in stagnant air will behave in the same way as a water jet in stagnant water. This means you can compare measurements of an air jet (in air) with a water jet (in water) after scaling the results properly. There must be hundreds of papers describing measurements and simulations of round and planar jet flows. The constants appearing in turbulence models were derived from such measurements! And you will quickly discover that even for such simple cases, some turbulence models will completely fail to predict even the most basic properties of such jets, like the spreading rate.
The best paper on measurements in turbulent round jets is
Hussein,Cap,George, Velocity measurements in a high-Reynolds-number, momentum conserving,axisymmetric, turbulent jet, Journal of Fluid Mechanics 258 (1994) pp. 31-75
As soon as you ignite your jet, you have to use measurements done in a reacting flow, off course.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 45 ·
