Measuring Attraction/Repulsion Changes in Sets: A Statistical Approach?
  • Thread starter Thread starter fer2000
    Comparison
The discussion focuses on measuring changes in attraction/repulsion among a large set of items represented in symmetric matrices. The user seeks statistical methods to determine the significance of these changes across the entire set and within specific subsets. Suggestions include converting off-diagonal components into vectors for easier comparison, calculating residuals between these vectors, and potentially applying weights to different entries. The aim is to quantify how closely related different matrices are and to explore any correlations with an external condition affecting all pairs. Overall, the conversation emphasizes the need for a robust statistical approach to analyze complex matrix data.
fer2000
Hello everybody!
I have a large set of items and, two-by-two, there exists some kind of attraction/repulsion that I have measured. I synthesize this information in a (nxn) matrix.
Under different circumstances this attraction/repulsion changes.
So, what kind of statistical/mathematical procedure can I use to measure whether the changes (for the whole set) are “large/small”, as well as if a subset of them (lets say the first ten items) the attraction is larger than in another subset (lets say the last ten items)?.
Thanks in advance
Mathematics news on Phys.org
Perhaps provide some sample data to help us understand what you are trying to get at?
My data are comprised in different matrices (each of the situations provide that information).
First one
x 1.3 -1.5 . . . . . .
1.3 x 1.2 . . . . . .
-1.5 1.2 x . . . . . .
Second one
x 1.1 1.3 . . . . . .
1.1 x -0.2 . . . . . .
1.3 -0.2 x . . . . . .
Third one
x -0.1 0.3 . . . . . .
-0.1 x 0.4 . . . . . .
0.3 0.4 x . . . . . .
All of them are symmetrical and the diagonal does not make sense (I could write any number). Note that the dimension will be around 300 x 300 for each matrix.
How can I say if first one is closer (and how closer is) to second one than to third one (as well as any other combination)?
Thanks again.
First one
Second one
Third one
1) How can I say if first one is closer (and how closer is) to second one than to third one (as well as any other combination)?
2) I care about an external condition, that is the same for all the pairs that generate the matrix (so, it has a single value for all the pairs in the matrix) , and I would like to know if the proximity could be related to that condition.
Thanks again.
I don't really get what you are trying to do with the matrices, but from what I understand:
(1) the matrices are symmetric
(2) only the off-diagonal components are important.
(3) they swing between negative and positive values.
Let me suggest some ideas? you could take the off-diagonal components and put them in a vector instead. Then instead of comparing 2 matrices, you compare 2 vectors.
Take the difference of the two vectors and call it the residual vector. If some entries are more important than others you can multiply each entry in the residual vector by different weights (assigned arbitrarily of course). Then take the modulus of this residual vector.
It sounds like you're trying to compare three metrics (or semimetrics): the abstract 'distances' between 300 points. Perhaps counting the diagonals as 0, scaling the matrices (multiplying each by a constant, if needed, so the numbers are around the same 'size') and then compare the least squares of the residuals.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
15K
15K
