Complex Analysis: Harmonic Conjugates
AUGTRON
For u(x,y)=e^{-y}(x\sin(x)+y\cos(x)) find a harmonic conjugate v(x,y) and express the analytic function f=u +iv as a function of z alone (where z=x+iy0
The Cauchy Riemann equations u_x=v_y and u_y=-v_x
and possibly:
sin(x) = \frac{e^{ix}-e^{-ix}}{2i}
cos(x) = \frac{e^{ix}+e^{-ix}}{2}
I've been toying around with algebra and I've been able to reduce up to u=\frac {e^{-y+ix}(y-ix)+e^{-y-ix}(y+ix)}{2} but I can't get past here. I have also noted that if I divide by i, u(x,y) becomes u(y,-x) so I can replace these variables and I have u/i = e^{x}(y\sin(y)-x\cos(y) which is, as someone on another forum pointed out, the real part of -ze^{z}. So I suppose I could write f=Re(-ze^{iz})i + iv no?
But how should I go about finding v? I am familiar with the straightforward procedure of finding u_x, integrating w.r.t v, then finding v_x and setting it equal to u_y... but I can't seem to simplify u to the point of easy differentiation. I don't know if I should just try to brute force it, or if that's even possible. It seems like u should simplify more.
I would not change the sine and cosine to exponentials, although you certainly can do so.
With v(x,y)= e^{-y}(x sin(x)- y cos(x)), v_x= e^{-y}(sin(x)+ y cos(x))+ y sin(x)) and v_y= -e^{-y}(x sin(x)- y cos(x))+ e^{-y}(-cos(x))
Now you must find u(x,y) such that
u_x= v_y= -e^{-y}(x sin(x)- y cos(x))+ e^{-y}(-cos(x))
and
u_y= -v_x= -e^{-y}(sin(x)+ y cos(x))- y sin(x))[/itex]<br /> <br /> Integrate either of those equations with respect to the appropriate variable, remembering that the &quot;constant&quot; of integration may be a function of the other variable, then put that into the other equation to find that function.
Great. I guess the integration wasn't as bad as I thought. Your algebra is a bit off because you wrote down a different u(x,y) than I had.
Using u(x,y)=e^{-y}(x\sin(x)+y\cos(x) I came up with
v(x,y) = e^{-y}(ysin(x)-xcos(x)).
Now my question is how to put this in terms of z only. I think I have a THM I can use: http://planetmath.org/encyclopedia/IdentityTheoremOfHolomorphicFunctions.html" . So if I have f(u,v) = e^{-y}(xsin(x)+ycos(x) +i(e^{-y}(ysin(x)-xcos(x)) can I say that some function g(z) is equal to f(z) along the iy axis of the complex plane (i.e. where x=o). Then f(z)=g(z) for all complex numbers. So f(z)=g(0+iy) ---> f(z)=ye^{-y}?
Sorry about the formatting, Latex is giving me trouble.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
