Complex Analysis: Integration
The integral to evaluate is expressed in terms of cosine using complex exponentials, transforming it into a contour integral over the unit circle. The integral simplifies to a form involving a quadratic equation in z, where the poles depend on the value of r. A suggestion is made to leave r in the equation to accurately determine the poles by solving the quadratic. Additionally, there are indications of algebraic errors in the last steps of the attempted solution, prompting a review of those calculations. Correctly identifying the poles is crucial for further evaluation of the integral.
Shay10825
Evaluate the following integral for 0<r<1 by writing \cos\theta = \frac{1}{2}(e^{i\theta} + e^{-i\theta}) reducing the given integral to a complex integral over the unit circle.
Evaluate: \displaystyle{\frac{1}{2\pi}\int_0^{2\pi}\frac{1}{1-2r\cos\theta + r^2}\,d\theta}
none
\displaystyle\cos\theta = \frac{1}{2}(e^{i\theta} + e^{-i\theta})}
\displaystyle{z=e^{i\theta}}
\displaystyle{ \cos t= \frac{1}{2}(z+ \frac{1}{z})}
\displaystyle{\frac{dz}{iz}= dt}
\displaystyle{\frac{1}{2\pi}\oint \frac{1}{1-2r[\frac{1}{2}(z+\frac{1}{z})]+r^2}\,\frac{dz}{iz}}
\displaystyle{\frac{1}{2\pi}\oint \frac{1}{z-2rz[\frac{1}{2}(z+\frac{1}{z})]+r^2}\,\frac{dz}{i}}
\displaystyle{\frac{-i}{2\pi}\oint \frac{1}{z-2rz[\frac{1}{2}(z+\frac{1}{z})]+r^2}\,dz}
\displaystyle{\frac{-i}{2\pi}\oint \frac{1}{z-r^2z^2-r+r^2}\,dz}
But I get stuck here. What do I do with the "r"? Should I factor it out, and if yes then how?
Thanks
Thanks
Leave the "r" where it is, the location of the poles will depend on its value...find those poles by solving the quadratic z-r^2z^2-r+r^2=0 for z...
Edit: You've also got a couple of algebra errors, double check your last 4 steps
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 34 ·
  • · Replies 19 ·
