Complex Analysis: Taylor's Theorem
tylerc1991
Find the Maclaurin series representation of:
f(z) = {sinh(z)/z for z =/= 0 }
{0 for z = 0 }
Note: wherever it says 'sum', I am noting the sum from n=0 to infinity.
sinh(z) = sum [z^(2n+1)/(2n+1)!]
=> sinh(z)/z = sum [z^(2n)/(2n+1)!] (referenced as (1))
=> the Maclaurin series representation for f(z) is (1) when z =/= 0 and 0 when z=0
Thank you for the help, I hope the text is not confusing.
Correct, but
The distinction is not necessary in this case. If z=0, then (1) already yields 0. Thus (1) is the series representation on the entire domain!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
