Solving Complex Analysis Problems: Where to Start?
In summary, the Schwarz reflection principle states if f(x) is pure imaginary then the conjugate of f(z)=-f(z*) where z* is the complex conjugate of z.
buzzmath
112
Can anyone give me some advice on how to solve this problem?
in the reflection principle if f(x) is pure imaginary then the conjugate of f(z)=-f(z*) where z* is the complex conjugate of z.
Any advice on where to start?
thanks
sorry I posted in the wrong forum
I assume 'f(x) pure imaginary' means pure imaginary along the real axis. In which case you might want to consider g(z)=i*f(x). What kind of a function is g on the real axis?
I'm assuming that they simply are asking for a graphic representation of this problem. In which case simply draw the imaginary part of z, which is simply a perpendicular line from the real axis to the point z, and z* would simply be the perpendicular line from the real axis in quadrant 4 of the Cartesian coordinate system.
? I have no idea what that is supposed to mean. The problem is, in fact, about extending the domain of definition of an analytic function. rbzima, aren't you supposed to be working on group theory?
thanks
How is this a problem (I see no (implicit) question mark)?
He's stating a variant of the Schwarz reflection principle. And trying to prove it.
LOL - This caught my attention, but I managed to finish my group theory stuff. Forgive me if I was wrong, but you don't really have anything to "solve" using what you stated. If f(x) is pure imaginary, it will exist on the imaginary axis, and it's conjugate will then exist on the imaginary axis as well. Maybe I'm just reading the question wrong.
Look up the reflection principle and then read the question again. He wrote f(x) is pure imaginary. He didn't write that f(z) is. This is intended as f(x) is imaginary when x is real. Purely imaginary analytic functions are pretty trivial.
The problem states:
Find the Radius of Convergence of the following Power Series:
(a) ∑ as n goes from zero to infinity of Z^n!
(b) ∑ as N goes from zero to infinity of (n + 2^n)Z^n
For (a) I think the radius of convergence is 1 but I'm a bit unsure of that...
racland said:
The problem states:
You are clearly in the wrong thread.
Thanks everyone I think I figured it out
1. What is complex analysis and why is it important?
Complex analysis is a branch of mathematics that deals with the study of complex numbers, which are numbers that have both a real and imaginary component. It is important because it is used to solve problems in many areas of science, engineering, and technology, such as in electromagnetism, fluid dynamics, and quantum mechanics.
2. How do I approach solving complex analysis problems?
To solve complex analysis problems, it is important to have a good understanding of the basic concepts and techniques. Start by reviewing the properties of complex numbers, such as addition, subtraction, multiplication, and division. Then, familiarize yourself with the different ways to represent complex numbers, such as in Cartesian and polar forms. Next, learn how to apply these concepts to solve problems by practicing with various types of problems and seeking guidance from textbooks or online resources.
3. What are some common techniques used in solving complex analysis problems?
Some common techniques used in solving complex analysis problems include using the properties of complex numbers, such as the distributive property and the laws of exponents, to simplify expressions. Another technique is to use the geometric interpretation of complex numbers, where they can be represented as points on a complex plane, to solve problems involving geometric figures. Additionally, using calculus techniques, such as differentiation and integration, can also be helpful in solving complex analysis problems.
4. How can I check if my solution to a complex analysis problem is correct?
To check if your solution to a complex analysis problem is correct, you can use various methods such as substitution, graphing, or plugging in values to verify if the solution satisfies the given problem. Additionally, you can also compare your solution to the answers provided in the back of a textbook or seek help from a tutor or instructor.
5. Are there any tips for approaching more challenging complex analysis problems?
Yes, when faced with more challenging complex analysis problems, it can be helpful to break them down into smaller, more manageable parts. Also, make sure to carefully read and understand the problem before attempting to solve it. If you get stuck, try approaching the problem from a different angle or seeking help from others. Practice and perseverance are key in successfully solving challenging complex analysis problems.
