Understanding the Complex Analytic Signal: Benefits and Uses | Forum Discussion
  • Thread starter Thread starter fisico30
    Complex Signal
The complex analytic signal transforms a real signal into a complex signal with only positive frequency components, simplifying analysis and operations. While real signals have a two-sided spectrum with negative frequencies that can be physically meaningful, the analytic signal's one-sided spectrum offers practical advantages. Key benefits include easier manipulation of complex signals, particularly in modulation scenarios, and a more straightforward representation for certain communication techniques like single-sideband modulation. The discussion highlights that while filtering out negative frequencies is an option, the analytic signal provides a more efficient framework for signal processing. Understanding these concepts is essential for effective signal analysis and communication system design.
fisico30
hello forum,
I might need some help understanding the usefulness of the complex analytic signal.
The world is made of real valued signals like x(t). Its Fourier transform can be one-sided, or, if we used complex sinusoids, two-sided and symmetric. So a real signal is only made of positive and equal amount of negative (complex) sinusoids. The negative sinusoids don't really a physical meaning, I guess.
The complex sinusoids seem to be useful. But then we come up with the complex analytic signal, which transforms a real signal into a complex signal with only the positive part of the frequency.
Ok, but what do we gain? We have been using the double sided spectrum. If we don't like the negative frequencies we could just filter them out.
thanks for any clarification
fisico30
Wait a minute, a real signal always has a two-sided spectrum, and it's Hermitian (that means that the negative half of the spectrum is the odd complex conjugate of the positive half). The negative half does have a physical meaning, as seen when you modulate a carrier with the real sinusoid. You get a two-sided spectrum around the carrier.
The real part of the analytic signal representation is the real signal, but the analytic signal has only a one-sided (positive) spectrum as you note. There are two advantages. First, many operations and analyses are easier to perform on complex signals than on real ones. Consider modulation of a carrier by an exponential as a very simple example. In complex notation it is trivial to see that the output is at the sum frequency
y=e^{i\omega_m t}e^{i\omega_c t} = e^{i (\omega_m+\omega_c) t}
whereas this requires a little work when expressed as real sinusoids. You can imagine the simplifications when dealing with truly complicated signals. Second, certain communications modulations such as single-sideband are naturally described by a (one-sided) analytic spectrum.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
