What is the dot product of complex conjugate vectors?
The discussion centers on calculating the dot product of two complex conjugate vectors, specifically expressed as $$\vec v^\star \cdot \vec v$$. Participants are encouraged to derive the result using the algebraic definition of the dot product. The vectors are defined in terms of their components, where each component is a complex number. The conversation emphasizes understanding the mathematical formulation rather than simply providing the answer. Overall, the focus is on applying the correct mathematical principles to solve the problem.
janu203
what is the dot product of two complex conjugate vectors?
$$\vec v^\star \cdot \vec v $$ you mean?
You can figure it out for yourself...
So let ##\vec v = (v_1,v_2,v_3,\cdots)^t## And ##\vec u = (u_1,u_2,u_3,\cdots)^t## where ##v_i,u_i\in\mathbb{C}##
What would ##\vec u \cdot \vec v## be, in terms of the components?
Now let ##\vec u = \vec v^\star##
sorry sir! i didn't get you
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
