Exploring the Image of Q Under f(z)=z^2
  • Thread starter latentcorpse
  • Tags
To summarize, the mapping f(z)=z^2 takes the quarter disc Q to a semicircle in the upper half plane of radius 1.
latentcorpse
1,444
Let [itex]Q:=\{ z: Re(z)>0, Im(z)>0, |z|<1 \}[/itex] i.e. the quarter disc.
what is the image of Q by the mapping [itex]f(z)=z^2[/itex]
by trial and error with various points, my answer is that it takes Q to the semicircle [itex]\{ z: Re(z)>0, |z|<1 \}[/itex]
but can't how this explicitly as it's not a mobius transformation with which I am used to dealing with.
The best way to find the image of mappings like this is to let [itex]z=re^{i\theta}[/itex] and then look at what your mapping does to this polar representation of all z in your region Q.
ok so the modulus will square but that's just 1 again and the argument doubles.
our original angle was from 0 to pi/2
so now we go from 0 to pi
so it will be a semicircle in the upper half plane of radius 1?
Looks good to me.
1. How does the function f(z)=z^2 affect the image of Q?
The function f(z)=z^2 squares every point in the complex plane, including the points in Q. This means that the image of Q under this function will also be squared.
2. What is the relationship between the image of Q and the original set under f(z)=z^2?
The image of Q under f(z)=z^2 is related to the original set by a geometric transformation. Specifically, it is a scaling and rotation of the original set.
3. Does the image of Q under f(z)=z^2 contain any points not in Q?
Yes, the image of Q under f(z)=z^2 will contain points that are not in Q. This is because the function f(z)=z^2 maps points outside of Q onto points inside of Q.
4. How does the shape of Q change under f(z)=z^2?
The shape of Q will be altered under f(z)=z^2, as the function will transform the points in Q into a different arrangement. The exact changes to the shape of Q will depend on the values and distribution of the points in Q.
5. Is the image of Q under f(z)=z^2 always a perfect square?
No, the image of Q under f(z)=z^2 will not always be a perfect square. The exact shape and size of the image will depend on the values and distribution of the points in Q. In some cases, it may be a perfect square, but in others, it may be a different shape or size.
