Complex numbers + linear algebra = :S
8 replies · 2K views
philnow
Find all complex numbers Z (if any) such that the matrix: (it is 2 by 2)
(2)(-1)
(4)(2)
multiplied by a vector V = ZV has a nonzero solution V.
part b)
for each Z that you found, find all vectors V such that (the same matrix)*V=ZV.
I'm not sure that I even know what this question is asking... could anyone clarify this a little?
And please don't mistake my lack of effort for laziness, I genuinely don't understand the question.
The question is "solve Av=zv".
(A is the matrix you were given)
(v and z are the indeterminate variables you're solving for)
(v is a vector variable)
(z is a complex variable)
So I'm looking for complex numbers such that, when multiplied by a vector, it gives the same results as the matrix multiplied by the same vector?
Yes, the number times the vector should be the same as the matrix times the vector.
I googled eigenvectors/values but I don't see the relevance to this question :s
How would I find a set of complex numbers that multiplies the same way as a matrix of real numbers? Any hints please?
I'm surprised you didn't see the relevance. But look, let v be column vector (x,y). So z*v is column vector (z*x,z*y) What is Av written out as a column vector? Now equate the two column vectors so you have a system of two equations, write them down. What condition does z have to satisfy to get a solution where x and y are not both zero? It's a quadratic. It has two roots. They are complex. See if you can find them. Look back at examples of finding eigenvalues again. Because that is what you are doing.
That makes a lot of sense, thanks Dick :)
