Complex organic molecules discovered in protoplanetary disk
Complex organic molecules, including cyanides, have been detected in the protoplanetary disk surrounding the young star MWC 480, suggesting that the building blocks of life are not unique to our solar system. These findings indicate that both simple and complex volatiles, such as methyl cyanide and HC3N, are present in significant amounts, similar to those found in comets. The research highlights the potential for abiotic amino acid synthesis due to the importance of C–N bonds in these molecules. Observations suggest that the rich organic chemistry observed in our solar nebula may be common in other star-forming regions. This discovery advances the understanding of prebiotic chemistry and its universality across the cosmos.
DennisN
(@mfb posted an article about this here, I think it deserves an own thread, and I did not find one, so I start one :smile:)
The comet-like composition of a protoplanetary disk as revealed by complex cyanides
Karin I. Öberg, Viviana V. Guzmán, Kenji Furuya, Chunhua Qi, Yuri Aikawa, Sean M. Andrews, Ryan Loomis & David J. Wilner
Nature 520, 198–201 (09 April 2015) doi:10.1038/nature14276
Abstract:
"Observations of comets and asteroids show that the solar nebula that spawned our planetary system was rich in water and organic molecules. Bombardment brought these organics to the young Earth’s surface. Unlike asteroids, comets preserve a nearly pristine record of the solar nebula composition. The presence of cyanides in comets, including 0.01 per cent of methyl cyanide (CH3CN) with respect to water, is of special interest because of the importance of C–N bonds for abiotic amino acid synthesis. Comet-like compositions of simple and complex volatiles are found in protostars, and can readily be explained by a combination of gas-phase chemistry (to form, for example, HCN) and an active ice-phase chemistry on grain surfaces that advances complexity. Simple volatiles, including water and HCN, have been detected previously in solar nebula analogues, indicating that they survive disk formation or are re-formed in situ. It has hitherto been unclear whether the same holds for more complex organic molecules outside the solar nebula, given that recent observations show a marked change in the chemistry at the boundary between nascent envelopes and young disks due to accretion shocks. Here we report the detection of the complex cyanides CH3CN and HC3N (and HCN) in the protoplanetary disk around the young star MWC 480. We find that the abundance ratios of these nitrogen-bearing organics in the gas phase are similar to those in comets, which suggests an even higher relative abundance of complex cyanides in the disk ice. This implies that complex organics accompany simpler volatiles in protoplanetary disks, and that the rich organic chemistry of our solar nebula was not unique."
Paper (Nature, and behind paywall):
http://www.nature.com/nature/journal/v520/n7546/full/nature14276.html
Paper (ALMA, open access):
www.almaobservatory.org/images/newsreleases/ALMA_nature_oberg012415.pdf
Article 1: "Complex organic molecules discovered in infant star system: Hints that building blocks of chemistry of life are universal" (ScienceDaily)
Article 2: "Complex organic molecules discovered in infant star system" (PhysOrg)
Pretty interesting, I think...:biggrin:
Edit: Found another article on the ALMA site:
"Complex Organic Molecules Discovered in Infant Star System: Hints that Prebiotic Chemistry Is Universal" (08 April 2015)
Quote from the ALMA article: "For the first time, astronomers have detected the presence of complex organic molecules, the building blocks of life, in a protoplanetary disk surrounding a young star, suggesting once again that the conditions that spawned our Earth and Sun are not unique in the Universe."
Astronomy news on Phys.org
I agree that this is interesting. I've been following it as well.
Thanks for the links you posted.
Imagine you have a pool containing all the elements that are present in living organisms we know , what is the simplest self replicating molecule (or a group of them) we know that can create it's own copies by "consuming" the atoms of different elements present around it ?
I have no idea :smile: (does anyone else here know anything about this?). My chemistry/biology skills are very poor. I'm just happy that I can read and understand the abstract and the basics of the report, and find that it is an interesting discovery, and that "protoplanetary" science seems to be taking steps forward.
The smallest self-replicating set of molecules is the million-dollar-question of abiogenesis.
Lol ..yes , it's just that I get frustrated every time I read " complex organic compounds found everywhere in the universe" kind of statements , it's as if however complex the compounds might be , they are infinitely far away from the simplest living things we know of.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
