Composition of Lorentz pure rotations
amyadad
Hello,
Given (in spherical coordinates) the resulting 4-vector K of the composition of 2 Lorentz pure rotations R1 and R2, where only R1 is known, I would like to find the angle of the "overall" rotation resulting from this composition.
In other words, I want to find the symbolic expression of the angle of the rotation R when :
R2.R1(U) = R(U) = K
and R2 is a known rotation and K is a known vector (R1, R unknown, U is a vector).
I first thought it would be easy but I have tried several equations and I have also tried to invert some of the rotations to simplify the equation but I should miss some point because I cannot find a reasonable expression (which I know do exist) for this angle.
Any help on that would be highly appreciated!
You actually don't need any reference to the Lorentz group - this is just the normal rotational group SO(3). There are quite some books that cover the parametrization of SO(3). I would suggest to start looking at the represenation of the group SO(3) in terms of so-called Euler angles. (just google it)
In general the composition of two general boosts will not itself be a boost, but will be a composition of a boost and a spatial rotation.
The doc
http://faculty.luther.edu/~macdonal/GAGC/GAGC.html
under '2.4.4. Composition of boosts' contains a treatment of an algebraic split of such a boost composition into rapidity and rotation angles ... but perhaps somebody else has a reference for you that is free of the clifford algebra used there.
amyadad said:
Hello,
R2.R1(U) = R(U) = K
By "Lorentz pure rotations" do you mean spatial rotations, as xepma has interpreted, or boosts, as Peeter has interpreted?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
