Compression Springs: Calculating Force Released
The discussion focuses on calculating the force released from compression springs using their specifications. The formula mentioned is Force = spring constant * extension, which simplifies the process of determining how high a weight will travel when released. A specific example is given where a spring requires 100g to compress fully, and the question arises about the height a 50g weight would reach upon release. Participants express relief at finding a straightforward solution after searching for information online. The conversation highlights the application of Hooke's Law in understanding spring mechanics.
bucky1andonly
Is there a formula to calculate how much force is released from compression springs knowing the exact specifications of the spring of course?
Like if it takes 100g to compress a spring completely, how high would 50g travel when the spring is released.
Force= spring constant*extension
That is normally how you would do it.
that simple eh, hmmmm, and here i was googling around the net wasting my time, thanks, hope youre right
It's called http://en.wikipedia.org/wiki/Hooke%27s_law"
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
